In the attached filter on a (MacBook Pro (Retina, 15-inch, Mid 2015), OSX 10.15.2 (19C57), using FF 9.006 the following issue occurs: changing Size, pixels from 600 to 598 using the default preset returns an overzoomed view of the image. More images and info to follow.
Iterated Madness 2.ffxml
Here is the image that is returned when changed Size, pixels to 598.
UPDATE: You may have to try other values, like 597, 596 etc. It does not always fail.
+1. Tested a little more. This does not occur in FF7 on the Mac using the same filter.
We've been unable to reproduce your issue. Could you make a video showing the steps to reproduce it?
Here is a video, I use the default preset of iterated madness, then change the Size, pixels to 598, then delete one character and change it to 597 to reproduce the issue.
FF9 Size pixel issue
+1 video in the previous post
