DeboraThom
Debora
I have figured out how to add the plugin but when I try to do it, it is not there. I have checked the file and nothing is there? How do I find it? And get it to work with PS Elements?
Filter Forge has never worked under PSE on macOs. Please check the list of supported host applications:
https://www.filterforge.com/download/hosts.html
You can copy and paste your images from and to Filter Forge instead of using a plugin.
DeboraThom
Debora
Hi Moderator - I have and PHotoshop Elements 2019 is supported but there is no plug in - I am still learning photoshop so would like to be able to use it inside the program like it says it can be used. Can you lead me to instructions and the plug in File so I can try to install it. I am getting an error saying
"One or more plug-ins are currently not available" and when I go to System Info it says it is there under Additional Plug-ins folder but not sure why it is not working and really would like some help. Thank you in advance.
DeboraThom
Debora
Actually now that I read the whole thing - it says it has failed to load? Why please?
DeboraThom
Debora
