Beat
Beat
I cannot paste text into the save dialogue in 'Save Image as...'.
This clearly seems a bug to me, as in any program I know this is possible.
Also, as far as I can see, all applications select the default name without the '.extension. FF in the save dialogue selects 'Untitled.tiff'. So I first have to select the default name without the extension before I can start typing. This is unconventional behavior.
I hope this can be solved very soon.
Beat
Beat
In addition and in a similar vein : the Notes for the Presets is a good idea. But the 'Enter' key does not work as it should. The 'Return' key gives a carriage return, like it should, but the 'Enter' key does the same, but should be equivalent to clicking the
'OK' button and close the Note.
I have encountered more little bugs or deviating behavior in FF, but they are not in my head right away. I will come back to them as soon as I encounter them again.
You can paste text via the context menu. Pressing Cmd+V doesn't work indeed, we're looking into this.
Beat
Beat
Thanks GMM, that is great news. Saves a lot of work. I hope that you'll manage to make Cmd+V working in the future, as well as that the ".extension" is not pre-selected in the save dialogue, so I can stay away from the mouse in the save process.
Thanks, Beat
Please try 9.006 and check if the Cmd+V issue has been fixed.
