Using the attached filter, If you change the integer range (min or max) using the Map Script input editor for the variable Selector, the program hangs (spinning rainbow).
Side note, this works correctly in Windows 7. This issue occurs on the Mac for both FF7 & FF8. megaswitch 2.1.ffxml Math meets art meets psychedelia. |
| Posted: April 17, 2019 12:01 am | ||
Posts: 3507 |
Thank you, the filter forwarded to the developers.
| Posted: April 17, 2019 8:31 am | ||
