The transparent option in the Polygonal Agamograph filter in FF8 does not work properly, the output has a lot of "chatter" in the areas that are supposed to be transparent. Using preset 5 (the first preset with transparency), here is the output in 8 bit PNG with transparency in FF8.
This is with the latest FF8 and MaC OS Mojave.
Here is the same Polygonal Agamograph, preset 5, output in FF7.
The issue also exists in the Windows 7 version of FF8, here is preset 5 of the Polygonal Agamograph output from Windows. FF7 on Windows works correctly.
Djekki
Filter Forge, Inc.
Filters: 2
Hi Rachel,
This issue is already fixed and will be released in the nearest update.
Regards,
Jane
12 unregistered users.
