azurblauw
azur
Last login: Thu Nov 22 09:35:59 on ttys000
Pascals-Mac-Pro:~ pascaltrouve$ /Applications/Filter\ Forge\ 8/InstallPlugins ; exit;
Searching for Adobe Photoshop CC 2019...
Adobe Photoshop CC 2019 found at /Applications/Adobe Photoshop CC 2019/.
Internal error. For details, see log file at /tmp/FFX PluginsInstaller.log.
Exception caught at thread 0xa98641c0 'Application':
<XFW::SystemCallError> ::mkdir(path '/Applications/Adobe Photoshop CC 2019/Plug-Ins/Filters') failed with error code 84: Value too large to be stored in data type.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
any suggestion try to manually instal Plug in but don't work
Please launch Terminal from Spotlight or Launchpad > Utilities and type this:
cd /Applications/Filter\ Forge\ 8/
sudo ./InstallPlugins
Sudo will ask you for an admin password, as InstallPlugins requires elevated privileges.
azurblauw
azur
Thank you, this helps!
Tilt the Band
Yes, that helps -
charles m
Charles
This no longer works.
I just tried to install on a brand new iMac and I keep getting permission denied
Last login: Tue Sep 24 11:07:40 on ttys000
iMac:~ charlesmarsden$ cd/Applications/Filter\ Forge\ 8/ sudo./InstallPlugins
-bash: cd/Applications/Filter Forge 8/: No such file or directory
Last login: Tue Sep 24 11:28:03 on ttys001
iMac:~ charlesmarsden$ /Applications/Filter\ Forge\ 8/InstallPlugins ; exit;
ln: /Applications/Adobe Photoshop CC 2019/Plug-Ins/Filters/FilterForge.pluginv8: Permission denied
Failed to install Filter Forge plugin for Adobe Photoshop CC 2019.
any ideas?
It works, if you do it accurately:
1. Type cd /Applications/Filter\ Forge\ 8/
2. Press Enter
3. Type sudo ./InstallPlugins
4. Press Enter
5. Type your admin password and press Enter
charles m
Charles
Last login: Tue Sep 24 12:03:51 on ttys000
iMac:~ charlesmarsden$ cd/Applications/Filter\Forge\8/
-bash: cd/Applications/FilterForge8/: No such file or directory
iMac:~ charlesmarsden$ sudo ./InstallPlugins
Password:
sudo: ./InstallPlugins: command not found
I am still having issues. I can launch filter forge as a stand alone application but not as a plugin. I have also dragged and dropped into the photoshop filter folder.
jjividen
Mac2core
I followed the GMM Moderator's directions and got this error message in Terminator:
Last login: Thu May 7 11:40:12 on ttys000
jerryjividen@Jerrys-MBP ~ % cd /Applications/Filter\ Forge\ 8/
jerryjividen@Jerrys-MBP Filter Forge 8 % sudo ./InstallPlugins
Password:
sudo: unable to execute ./InstallPlugins: Bad CPU type in executable
Any ideas on now to get the plugins working is Photoshop 2020 using Catalina?
Anvil Hammer
Solution to Photoshop Plug-in fail on Mac. This is copied from user M_L on another of this forum's posts. I tried this using Mac OS Catalina, FF 9 and PS 2020 and PS 2021 and it worked for me (Anvil Hammer).
_______
Shut down Photoshop
In Finder, open: Applications > Filter Forge 9
Make an alias of 'Filter Forge 9 universal.plugin'
In another Finder window, open: Applications > Adobe Photoshop 2021 > Plug-ins
Copy alias to the Photoshop Plug-ins folder (do not actually copy the plugin - it must be an alias!) ← Will ask you for admin privs
12 unregistered users.
