I've attached a sample that illustrates the issue. Bomber+ issues a warning at the particle input if the Particle Adapter is put behind a switch. Go in to the editor and check and uncheck the Portrait/Landscape switch. A warning is always issued even though Bomber+ receives PA input.
This works correctly in FF6. Let me know if this a new "feature" or a bug. I have many filters that use this concept (Detail Painter for example).
Switch - Particle Adapter test.ffxml
This is a side effect of the newly-greened Selector input. Since it is now a map input, it has no way to predict what HDR color will arrive through this input and what selector position it will be mapped to.
I fully understand your concern that this behavior may be undesirable. Unless Vladimir decides to change that, please use the old Switch 6.003 component instead.
Thanks GMM. Makes sense. With inputs other than controls, all is possible. Using Switch 6.003 does indeed solve the problem.
