BarbMc
Posts: 8 |
I just purchased version 6 which is advertised to be fast and to have lots of effects. The program is actually cumbersome. It loads in PS, then sends the image to the standalone version of the program, applies the limited effects to a reduced sized image which it works on in very slow mode. To see the effect one my change the view to actual and then the program recalculated. It slowly sends the image back to PS where it must recalculate again. This is just unacceptable and the finished results seems unacceptable to me. I've attached image. The program is supposed to handle larger images but boy this is way to slow.
Machine: iMac Retina 5K running OS 10.13 Model Name: iMac Model Identifier: iMac15,1 Processor Name: Intel Core i7 Processor Speed: 4 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 8 MB Memory: 32 GB |
| Posted: October 1, 2017 6:16 pm | ||
xirja
Did you use the trial version before purchasing to get a clear idea of the capabilities?
The thing about Filter Forge is that since it is a DIY node based filter kit, many of the effects can not be optimized as much as a standalone plug-in that is a one trick pony that is tailored to one specific task. Changing from "reduced" to "actual" requires a complete recalculation because the pixel resolution changes. You don't have to wait for the "reduced" rendering to finish and can switch to "actual" right away to save time. Also FF has only CPU and not GPU calculating, so compared with many of todays programs it is rather, aaaa... bespoke? I gave up on PS when it went cloud subscription only, so I can't comment on that possible part of the issue. _____________________________________________________
| Posted: October 2, 2017 9:50 am | ||
BarbMc
Posts: 8 |
I didn't. I purchased it because it seemed to be it was capable of great user control. But it applies the effects to a smaller image, if you increate the image size the whole thing becomes even slower. I tried to check a few other 'presets' and eventual Filter Forge stopped working. There's a preset that has a blue bird on it. My image became that blue bird! This is clearly Filter Forge's inability to use mt machine. Right now I'm really disappointed.
| Posted: October 2, 2017 9:59 am | ||
BarbMc
Posts: 8 |
| Posted: October 2, 2017 10:01 am | ||
BarbMc
Posts: 8 |
| Posted: October 2, 2017 1:39 pm | ||
BarbMc
Posts: 8 |
I just closed PS and reopened it. I loaded a test photo and and went to Filter Forge and Fiter Forge applied the last filter and then threw up this message. I don't understand.
| Posted: October 2, 2017 1:47 pm | ||
BarbMc
Posts: 8 |
Pardon me, is this not the correct place to report a problem? Thanks,
Barb |
| Posted: October 2, 2017 1:48 pm | ||
EAdams
Posts: 448 |
Hi Barb,
I've used Filter Forge from Photoshop but I have never come across that particular error message, so I'm sorry I can't help you there. I think I might know why FF puts the bird on your image. When you have sel ected the filter preset, click on the Settings tab to view the filter's settings. There should be an option to select the image to be processed. You only need to replace the sample kingfisher image with an image of your own. There is a reason why some filters want you to select an image fr om within the filter settings, but I can't recall why. Some filters let you load more than one image this way. For example the filter Alphabet Texture Creator by SpaceRay lets you load a foreground image and a tint image fr om the filter settings. https://filterforge.com/filters/11659.html In my experience, for general experimentation to see how filters look on one's images, it is best to open FF as a stand-alone. That is a lot faster than using the program fr om Photoshop. When you tweak a filter by experimenting with the sliders in the settings or find something you like just by clicking on the "Next Variant" button in the settings, don't forget to go back to the presets tab and click on the little drop-down symbol at the top right of the preset window and select "Add preset" to add your own private presets. Then when you want to do your final work in Photoshop your new presets are there for you to use. Filter Forge takes some getting used to, and as you have noticed, it is not the fastest thing on earth, but it can do very creative and marvelous things. |
| Posted: October 2, 2017 8:22 pm | ||
