LexArt
LexArt
I have seen something that I do not know if his may be a bug, or because I am doing somethig wrong
When you want to search for a filter, it will only show you results from the filters downloaded from the FF library, there will not appear any result from any of the custom filters
If I modify a filter from the library that has all the keywords, and then save it to a custom folder, it will not be found by the search, I have to search foor it myself
Is the search only working for downloaded filters? Or is this an error?
Thanks
Using latest version of FF 5.010
LexArt
LexArt
i have made more tests and I was wrong because I can search inside custom folders, but what I can not do is search inside the Latest filters folder, anything that is inside this folder is not seen by the search
I have also discovered that I had by default the save filters in the Latest Filters, so any filters that I was saving was going to the Latest Filters folders and so it did not appear in the search
now I have made the folders as default to save the filters and now the search works correctly inside the my filters folder
Sorry for the possible confusion, I did not know what was the problem, now is fixed
