reventon_p
Posts: 2 |
I have re-installed Filter Forge 4.015 Professional Edition several times since the new Photoshop CC 2015.5 update earlier this month and the plug-in does not appear in PS. Will there be a update to fix this problem or do I have to dish out more cash.
| Posted: June 29, 2016 12:02 pm | ||||
Posts: 3507 |
I'm afraid the lifecycle of Filter Forge 4 has ended: generally we don't update earlier program versions once we release a new one.
As it has been noted in another thread, this is why there is the "keep previous version" option when you install a Photoshop update. You can still use Filter Forge 4 in the standalone mode or under a supported host application. |
| Posted: June 29, 2016 12:24 pm | ||||
Grosvenor
Posts: 20 |
Can't older versions manually update? When I was trying to figure out what was going on with my plugin filters, I found this on the Topaz site:
Topaz Update Instructions The Topaz folks provide a link to their updated installer that fixes the issue now and going forward, but also gave instructions on how to do it manually with the warning that if you go the manual route you'll have to ultimately do it again with successive Adobe updates:
Perhaps following Topaz' road map would address the issue. |
| Posted: June 29, 2016 12:48 pm | ||||
reventon_p
Posts: 2 |
Thanks for the quick response. No problem. I just upgraded to 5.0 and in the near future I will just subscribe to Filter Forge so I do not have to worry about the latest updates. Thanks for the great plugin!!!!!!!
| Posted: June 29, 2016 1:00 pm | ||||
15 unregistered users.
