LexArt
LexArt
Hello, I have tried to use the Pixel Awarness feature shown here
There is a PixelGrid.fmxl example to download.
I have downloaded it, double click on it to install it, and nothing happens, it seems that it does not work
I have tried to copy directly the filter to a custom filter inside FF, but it is not showing
I am using latest version Filter Forge 5.09 with MacOS 10.10.4 Yosemite
Thanks for any help
Where did you copy it to?
You need to place the .ffxml file into /Users/Your_User_Name/Library/Application Support/Filter Forge 5/My Filters/
and restart Filter Forge.
LexArt
LexArt
ok will try now
LexArt
LexArt
I have already put the filter exactly where you have told me and when FF starts I get this error shown on the screenshot below
Although it is said that is not found, it Now it DOES appear in the filter list, but immediately that I try to use it FF crashes
Process: Filter Forge [8248]
Path: /Applications/Filter Forge 5/Filter Forge.app/Contents/MacOS/Filter Forge
Identifier: com.FilterForge.FilterForge5
Version: 5.0
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: Filter Forge [8248]
User ID: 501
Date/Time: 2016-03-17 14:18:58.603 +0100
OS Version: Mac OS X 10.10.4 (14E46)
Report Version: 11
Anonymous UUID: 3C2C8BC6-966D-11C4-FA52-54D58D2EE312
Sleep/Wake UUID: 3F0C7612-84A6-4F07-BB69-6C3C8D40DF92
Time Awake Since Boot: 360000 seconds
Time Since Wake: 630 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
__TEXT 0000000000001000-0000000000e31000 [ 14.2M] r-x/rwx SM=COW /Applications/Filter Forge 5/Filter Forge.app/Contents/MacOS/Filter Forge
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.FilterForge.FilterForge5 0x00601717 std::__1::__split_buffer<FFXLib::RandomizePresetItem, std::__1::allocator<FFXLib::RandomizePresetItem>&>::~__split_buffer() + 12003
1 com.FilterForge.FilterForge5 0x00627178 std::__1::__split_buffer<FFXLib::RandomizePresetItem, std::__1::allocator<FFXLib::RandomizePresetItem>&>::~__split_buffer() + 166212
2 com.FilterForge.FilterForge5 0x00093876 FFX::FetchingExceptionEvent::clone_object() const + 203006
3 com.FilterForge.FilterForge5 0x000a15ec XFW::OS::MethodEventHandler<FFXLib::CheckUpdatesReadyEvent, FFX::FilterBrowserForm>::operator==(XFW::OS::MethodEventHandler<FFXLib::CheckUpdatesReadyEvent, FFX::FilterBrowserForm> const&) const + 8414
LexArt, our MacOS tester is currently on vacation. We'll look into your issue when he is back to work.
I still suppose something in your system got cached incorrectly. Please do that once again:
- remove the ffxml file from the My Filters folder;
- start Filter Forge and check the filter doesn't show on the filter list;
- close Filter Forge and copy the ffxml file back;
- run Filter Forge and check if it helped.
LexArt
LexArt
Thanks GMM I have tried your suggestion, and the first time I did it, it gave a direct crash, but I tried to repeat all the above again, and then on the second time, it did work correctly, and now it seems to work and I can use it.
thanks for your help
I do not know why it was happening
updated: When closing filter forge it crashed again
