ahoeltje
Posts: 6 |
Six SIGABRT crashes today:
5: Assertion failed: (r->shape != NULL), function assert_check_region, file Regions/CGRegion.c, line 28. Originating at FF code: com.FilterForge.FilterForge4 0x006f551b Controls::ColorPlanePanel::~ColorPlanePanel() + 26147 and com.FilterForge.FilterForge4 0x00725b20 Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 2538 1: Assertion failed: (shape != NULL), function assert_check_shape, file Regions/shape.c, line 155. Originating at FF code: com.FilterForge.FilterForge4 0x00725b20 Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 2538 I can send complete crash logs if you would like them. The crash usually happens on launch but a couple of times it has happened after I have saved a filter. I am running FF as a stand alone application - photoshop is not involved. Filter Forge 4.014.36521.36521 Release-10.5 June, 2015 13:36 Professional Edition Model Name: Mac Pro Model Identifier: MacPro6,1 Processor Name: 6-Core Intel Xeon E5 Processor Speed: 3.5 GHz Number of Processors: 1 Total Number of Cores: 6 L2 Cache (per Core): 256 KB L3 Cache: 12 MB Memory: 32 GB Boot ROM Version: MP61.0116.B15 AMD FirePro D500: Chipset Model: AMD FirePro D500 Type: GPU Bus: PCIe Slot: Slot-1 PCIe Lane Width: x16 VRAM (Total): 3072 MB Vendor: ATI (0x1002) Device ID: 0x679e Revision ID: 0x0000 ROM Revision: 113-C3861J-687 |
| Posted: August 16, 2015 8:26 pm | ||
Spaz8
Posts: 10 |
Agreed! About 4 crashes in the first 30 mins of upgrading from 3 pro to v4 pro. Disappointing. I have a nearly identica setup, and was also running stand-alone.. on osx 10.9.5.
I am running FF as a stand alone application - photoshop is not involved. Filter Forge 4.014.36521.36521 Release-10.5 June, 2015 13:36 Professional Edition Model Name: Mac Pro Model Identifier: MacPro6,1 Processor Name: 6-Core Intel Xeon E5 Processor Speed: 3.5 GHz Number of Processors: 1 Total Number of Cores: 6 L2 Cache (per Core): 256 KB L3 Cache: 12 MB Memory: 64 GB Boot ROM Version: MP61.0116.B15 AMD FirePro D500: Chipset Model: AMD FirePro D700 Type: GPU Bus: PCIe Slot: Slot-1 PCIe Lane Width: x16 VRAM (Total): 6144 MB Vendor: ATI (0x1002) Device ID: 0x679e Revision ID: 0x0000 ROM Revision: 113-C3861J-687 |
| Posted: November 16, 2015 1:32 pm | ||
I hate to say this, but I have been a long time user of FF 4.0xx, and it has crashed a lot of times in my time of using it on OS X 10.9 & 10.10. I've reported a bug which illustrates the problem in the Beta 5 section of the forum:
[crash?] repeated preset clicking crashes FF5 It appears that when many threads are running (and terminating) that some sort of memory allocation issue or "collision" of some kind occurs that crashes FF 4. Although I reported the bug in FF 5 beta, it also occurs in FF 4. Try it. You can also try the technique on other filters, with varying results. FYI: it crashes a lot on exiting the editor. A workaround. Save the filter with Command-S, then Cancel. It seems to help for me. Math meets art meets psychedelia. |
| Posted: November 16, 2015 2:19 pm | ||
Spaz8
Posts: 10 |
Are you finding FF5 beta on OSX any more stable?
| Posted: November 16, 2015 2:26 pm | ||
Yes, it is somewhat better, especially on issues with file formats (16 bit PNG) that I was seeing in FF 4. FF 5 beta also renders large output (say 8192x8192) better where FF 4 might have crashed. But the fundamental thread/memory issue (leaking memory?) still remains from what I've seen as I've used FF 5 beta.
My 2 cents. I really don't like reporting these things, I know this at a tough time for FF, now deeply into getting version 5 finished. But, I have to call it as I see it. I'm a Mac user of FF... Math meets art meets psychedelia. |
| Posted: November 16, 2015 2:36 pm | ||
ahoeltje
Posts: 6 |
I am guessing that version 5 is not a complete rewrite so in that case reporting crashes in version 4 should assist with shaking down potential bugs in v5. If v5 crashes less often than v4 then that would be reason enough to upgrade! Filter Forge is a fantastic tool and I would not want to be without it now.
| Posted: November 16, 2015 9:42 pm | ||
My take on that: you might try out beta 5, you just have to request a serial number. I think reporting bugs in beta 5 might get more notice at this point, so post your [bug] or [crash] reports in the Beta 5 forum as a new topic. Make sure the bug is reproducible and clearly explain the steps to create the problem & your OS version & the FF program version + any filters/files needed to reproduce the problem. Crash logs are only somewhat helpful.
| Posted: November 16, 2015 11:04 pm | ||
Spaz8
Posts: 10 |
Is there some trick to opening an image in FF4? 5 crashes in a row with the same TGA, then tried a png.. dif filter.. crash.
| Posted: November 19, 2015 2:54 pm | ||
C0ppert0p
Posts: 3 |
4.015 Crashes in the morning
crashes in the evening crashes at supper time..... choose locate a file... crashes. not even a dump-file is created install a new filter... crashes sometimes. Open FF.... crashes sometimes Reopen FF... doesnt crash. System Version: OS X 10.11.4 (15E65) Kernel Version: Darwin 15.4.0 Boot Volume: Macintosh HD Boot Mode: Normal Model Name: MacBook Pro Model Identifier: MacBookPro10,1 Processor Name: Intel Core i7 Processor Speed: 2.7 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 8 MB Memory: 16 GB Boot ROM Version: MBP101.00EE.B0A |
| Posted: March 27, 2016 2:06 am | ||
Valp
Posts: 1 |
I'm currently having same issue, hoped FF5 will be more stable than FF4.015 but it crashes too. I'm opening file and crash... Often it crashes during rendering.
So now even FF4 works better than FF5 (trial) - not sure if I will upgrade until this issue is solved for real :/ MBP retina mid 2012 OSX 10.11.5 2.6 GHz i7 16GB Ram gfx: NVIDIA GeForce GT 650M 1024 MB |
| Posted: June 15, 2016 6:12 am | ||
Posts: 3507 |
Valp, have you tried FF6 beta? It is completely rewritten in Cocoa.
| Posted: June 20, 2016 6:24 am | ||
ahoeltje
Posts: 6 |
I just ran FF6 beta through a few quick hoops that normally would crash FF4 and 5 - nothing special, just rendering a large image and clicking on settings before the previous setting was done rendering - and did NOT make it crash. !-) This is just a preliminary test, I am real busy right now and will not have time to really use it for a few days, but it looks very promising! Thank you Filter Forge!
-Allan |
| Posted: June 20, 2016 2:28 pm | ||
