Shiggel
Hi,
I'm a total noob. smile:D I just downloaded the Filter Forge trial to see what all the fuzz is about. After installing it (Mavericks, Photoshop CC 2014), I started Photoshop.
I can't see anything related to Filter Forge in the menus. Am I blind?
How do I actually get started using FF?
EAdams
Filter Forge should show up in the Photoshop Filter menu. Have a look at this thread to see if it helps.
Alternatively, you should be able to run Filter Forge as a standalone application without Photoshop.
Shiggel
Hi,
thanks for the reply. Sadly I'm quite new to OSX, so I won't be able to follow most of the suggestions made in that thread.
I don't want to sound like a jerk, but why the heck should I pay 400 bucks for a plugin, that does not even install correctly? I assume the paid version has the problems as the trial version, right?
This makes it quite unusable for me. And it also doesn't reflect well on the Filter Forge's developers skills...
This is what the trial version is for. You can use a fully-functional version for 30 days and decide if it's worth its price.
17 unregistered users.
