Targos
Game Dev
I'm waiting on a filter to do its thing - as Photoshop plugin. Been about 30 min so far.
Is there a way to tell if a filter is actually still alive or just crashed?
30 minutes is not too much on some filters, I have had some of them for 45 or 55 minutes.
All depends on which filter you are using and what resolution size are you using for the render result
what filter and what size are you using?
The only way I know to tell if a filter is still alive is the green bar progress that is shown with the photoshop plugin, even if it is growing or moving very slowly, it should move at least every 5 minutes or so, if not it is probably frozen.
Targos
Game Dev
Its the "Glowy" *? something at A4 res. Alas as I've command+tabbed to other apps in the meantime theres no progress bar to be found..
is this filter? Glowy by Sharandra
When I asked for the size, I was refering to what size in pixels you have configured the output, for example, 5000x3500
You are using Mac, but what version of FF are you using, 3.0 or 4.0, and have you downloaded the latest version available?
What Photoshop version are you using?
Using FF as plugin, you must first be able to preview the result in a reduced size to know what will look like when applied to the photoshop image source, so:
How long does it take to preview inside filter forge plugin with the Glowy first preset on your loaded image from photoshop?
Because this should be faster and know if then if the filter works or not.
Well, with other filters I have had a FF progress bar, but now I have tested myself with a 7000x7000 image and is true that it does NOT appear any progress bar after 25 minutes waiting using FF 4.0 anf Photoshop CC
Mine is also like frozen smile:?: smile:?:
THERE MAY BE A PROBLEM WITH THE FILTER AND HIGH RESOLUTION
AS PHOTOSHOP PLUGIN 7000x7000
Well after nearly 1 hour waiting for something to happen on the way fr om FF plugin to Photoshop, I had to cancel it using Esc key because it seems that it will not work.
This is weird and do not know why this happens, because using the filter in reduced mode view works right and using other filters it works well.
STANDALONE MODE 7000x7000
I have tried to use the same filter in standalone mode with the first default presets and an source image of 7000x7000 and after waiting half an hour NOTHING happens and does NOT appear any part of the image, so it seems to be frozen somewhere.
STANDALONE MODE 2500x2500
Trying to lower the resolution with an image source of 2500x2500 it works very well without any problem and does not get frozen
STANDALONE MODE 4900x3500
When using an image with 4900x3500 and switching to "Actual size" view, something appears but then later it gets frozen sometimes, and in 20 minutes only shows a tiny part done.
I have the latest version of FF 4.0.9 February 7 and using Windows 8 64 bit and Intel i7 Quad Core 2600K 3.5Ghz
Targos
Game Dev
Thanks for checking this SpaceRay, I left it overnight and it still didn't complete the render.
Hopefully the devs can reproduce it and spot the bug.
A4 is 2480 x 3508 at 300 ppi and yes it was that Glowy filter. It did begin to render in the preview, but assigning it to the image seems to fail.
AaronC
Well one of the biggest reasons is that there is a lot of blurs in this filter...One or two can slow down a render at that size let alone what this filter has...
So if I were to give a definite reason why its slow are all those blurs..
Yuya
All the blurs in there!!
Suggestion: turn off anti-alias.
Some filters that are heavily based on bitmap components never finish rendering. I confirm that and confirm we're looking into the issue.
Retoucherpro
Retoucherpro
I find that FF is just plain slow period. Rarely does it use more than 12% of my cpu's or even touch ram. Being a "resolution" independent filter it should be able to utilize extra cpu AND ram if its available for rendering at higher dpi(ppi). Heck even at 100ppi I have to wait hours for the majority of filters, never mind at print resolution. With 26 gigs of ram and 2 x 2.4 GHz Quad-Core Intel Xeon and it STILL never goes over 12% cpu theres an issue that needs to be addressed. I wouldn't mind if it was slow and using a majority of cpu available.... but its like driving a fast car with the accelerator pedal stuck at the top 1/4 of its range.
Sharandra
Filter Forge Addict
Retoucherpro, have you checked if it is set to use all available cores?
It´s under Options>Rendering.
I sometimes set it to use only one core, when I need to do other stuff while it renders. If I forget to set it back, I wonder about it´s slowness next time, until I remember lol smile:-)
And sorry about the slowness of my Glowy filter. I tested it on fotos and a 4096x4096 texture before I submitted it and it worked just fine for me, only slow.
Retoucherpro
Retoucherpro
Ghostcat
Thanks for the reply even though I wasn't talking about your filter specifically in general. Much appreciated.
Yes... I have FF set to use all available CPU's/cores and a maximum RAM usage of 80%.
I get the same speed out of the previously mentioned setup with the XEON processor that I do with an i7 and 32 gigs of ram...
slow... sigh.. so much potential
Again thanks very much... I'll check out your filters soon.
oreosPaul
oio
There is an obvious bug only on the mac platform in reference to rendering above a specific size. And its been known for at least a year in reference to the plug in "paint HDRtist" Such a great plug in, and pretty much the reason I bought the last upgrade of Filter Forge. I thought that it was my computer speed or ram etc... But I upgraded computer and ram etc... and still the same. I only recently read through the comments about the plug in, ... http://www.filterforge.com/filters/10787.html , and found that people where having this issue a year ago?..
So annoying!... There should just be a different price for the mac users if the mac version is going to be restrictive compared to the PC version.
At the very least it should be available to everyone to know of this restriction in the mac version before anyone attempts to purchase it. I know I wouldn't have purchased the latest upgrade if I had known this.
So does this happen with all plugins?...or just some?.... So annoying. smile:evil:
Retoucherpro
Retoucherpro
OreosPaul
I get this on a LOT of filters... for the most part FF is just slow.
Yuya
Ok, just speaking on my part, on every software forum I visit excepting a couple there's always bound to be an argument stating some software X is slow in doing task X. Mentalray according to some people, is slow. Even Vray, according to some folks, is slow. I work with all sorts of software everyday, VFX related, motion graphics, you name it. I have to deal with "slow" all the time and you gotta rethink your strategies. FilterForge is no different. I do admit, sometimes I do think FilterForge is slow, but I work with that. I feel like complaining, but I'd be complaining about every software I'd be using, so I don't.
These forums are naturally a place where people post about sluggish speeds, it's ok to do that. But the forums should also be a place where there are solutions as well, and I'd rather help people out than leave arguments around. I just need a bit of openness from people than facing a wall of bitterness.
My case and point:
1. Things do run slow... if you just let them be.
2. There's no such thing as "instant". Software companies demo "instant" a lot but in reality, it's hardly the truth. We work long hours to make "instant" happen. I optimize tons of things so demos would run smooth, so games would run smooth, so shaders run really smooth. I sometimes feel people get the false impression about "super fast render speeds" based on some company tech demo... the reality is really harsh.
3. There are always ways to shorten render times. <--- Ladies and Gentlemen, workflow optimization is a major portion of my job.
4. I can help!
oreosPaul
oio
I think I have to take out some time and respond with a long comment..forgive my indulgence lol. might take 3 lots of messages to get all through..
oreosPaul
oio
Yuya... First of all thanks for offering to help, you sound like you probably would have lots to offer too, so hopefully you might be able to shed some light,... I personally look for inspiration or direction from anyone who offers any thoughts on problem solving.
But I have noticed you became defensive in response to a similar comment I made here .... http://www.filterforge.com/forum/read...sage125871
I'm not sure why your so sensitive to truthful negative "constructive" criticism. I don't think I was being too hard either.
Just because i'm saying how it is... doesn't mean its not constructive, in fact thats the very reason why it is.
[QUOTE]3. There are always ways to shorten render times. <--- Ladies and Gentlemen, workflow optimisation is a major portion of my job. [QUOTE]
Too be honest I think that is obvious. ( I like how you categorize it as workflow optimisation, hits the nail on the head). There is no other way to work through graphics software, other than workflow optimisation... and the software you use should help in optimising your workflow. And Filter Forge does ,.... as I have said before, if it actually was working properly, with out that bugs.
I have been working with photoshop since the beta version before version 1.0 , so thats close to 25 yrs.
Over half my age.
oreosPaul
oio
In all that time I have had experience with Mental Ray,... Electric Image (god that was such a fast renderer)...After Effects,..and so many 2d and 3d , and photoshop plug ins . Pixar render man was sooooo slow, but so worth the effort and patients needed to use it. I think filter forge is in a similar boat.
Even with the lightning fast Electric image ,.. Computer graphics has always needed a very crucial important skill set.
Patients... So yeah I agree with you on that.
Mental Ray as you mentioned can blow up and halt any rendering no matter how much ram you have. Same as After Effects... ect,..but you have some direction offered within the software to fix things.
There is tools within the software for you to make conscious decisions into improving your speed... or at least adjust it and you get feed back constantly giving you an indication on how long it will take to render. No matter if you leave it for a week, at least it will do as it has promised,...and render.
The freaky thing is that with Filter Forge, as you tweak and confirm the inputs to render the file,... your effecting the actual image, not just a representation of it through a basic 3d shape like a sphere.
You render the image within the tweaking stage in Filter Forge and choose "actual image" and bump up everything on the quality..and it renders the file(slowly)....so it actually is proving to you it can render it, with an indication on how long it takes to render it as you see it happening in front of your eyes.
But wait.... it's all a lie.
When you hit Apply, ...it then will freeze.... and for the most part leaving you baffled as to why?
oreosPaul
oio
If the file is 4000 x 4000 or bigger in size, it seems to be too much for it. If it's close to that size but smaller it can take for ever to render...or just render half way and then freeze. If you get to a much smaller size ..everything is fine it works well.
Now if this was to happen in mental ray and only happen for the mac users and not for the PC users..or UNIX users... There would be lots to hear about in forums from the annoyed mac users trust me.
I believe there's one price for all users on all platforms, so I don't think its much to ask to have the same features working just as fast or slow on all platforms... Having the Filter Forge freeze and not render on the mac and having it render fine on the pc is not a small thing to not worry about... Unless its only happening to me..and the few others I have seen mention this around the forums. (even still why is it happening to us?)
It would have to be something in the compiling of the software over to the mac version. Something to how it addresses ram, but I'm not skilled enough to make an accurate guess,...but seems to do with Filter Forge accessing the ram.
It might be a really hard thing to fix...I'm not sure I don't have the knowledge to comment on that. How ever there has been reports of this for a long time. And it seems to be ignored? I wonder, if it was ignored possibly because there wasn't anyone making a big enough fuss?
I wish there was more like Retoucherpro, to make even the smallest comment. Negative or positive. There hasn't been enough people speak up.
I was one that didn't speak up,. I actually thought it might have been an issue with me not having enough ram, but I have lots more now and still no go. It might only be a few of us that this happens to..or it might be a hell of a lot.
We won't know unless there is feed back from people. Maybe the lack of feed back shows that there isn't many others, other than the ones that have spoken out already........... or it could mean people just gave up and moved on.
There is a reason why I'm spending all this time typing this out and expressing my thoughts.
I am motivated to NOT walk away because I believe in this powerful software and am attracted to the way it works, and I think its unique and nothing else on the market like it.
But if making it better,.. or saving it from becoming virtually worthless (to me personally at least), then I find no problem giving honest feed back in a relevant forum. How ever short..... or long,.. that feed back is smile:D
Yuya
oreosPaul, I think the only reason why I'd feel a bit defensive is because we're both on the internet. I don't know you, and you don't know me.... which really adds to the flavor. Also the fact that you threw probably 5 posts on the same topic just added to my thoughts and feelings. Basically put, you kinda sounded incredibly impatient... and that doesn't sit well with me. But ... err uhh sorry. I don't intend on sounding like a defensive guy. I've worked with pretty complicated situations and managed to find pretty decent solutions for most of them, so I basically don't like having a dangling "software X is slow, so be it" kind of thing. Cause FilterForge, and many other "slow tools" can go ridiculously fast if you settle with a proper plan.
Gonna have to cut the message short. I did read your post though. Sorry if I'm not responding to the main points. But I get what you mean.
Believe me, I've been on the FF forums for years and there were a bunch of times where aggressive comments were left around, so people do speak up.
Personally, I strongly believe it's the company's duty to invest in further improvements in such important fields! But sometimes arguing on the forums doesn't cut it.... Sometimes complicated pieces of software need a major rewrite for it to work even better. Companies have done that, and it's not easy given the fact that you have to review code that you've been writing for years.
Just a note, on OSX, Carbon support has been long gone since Cocoa took over. Which makes porting software not so easy. But I really don't have too much clue on the technical stuff. My friends in this field could answer though.
Retoucher
Retoucherpro
Yuya
My comments are/were not aimed directly at your work. Like oreosPaul I have been in the industry a LONG time and on a variety of hi and lo end equipment used to render graphics of all sorts. I'm USED to waiting a longish time for something to render out or a filter to complete its cycle. When FF first came out I was quite excited about what it could mean to a lot of different industries that deal with creating graphics of any kind. But I held off then because it was just too slow for the work that I do.
Now...... well, things might have changed in some areas with FF and what it can accomplish. Truly amazing stuff. And some filters are wickedly fast and give me something that I can tweak from.
And some are just wickedly slow..... and I don't think that its the person who created the filter's fault at all. There is some computational heavy stuff going on. I just feel that the creators of FF need to do something to make their product a bit more optimized for ALL systems to accomplish their claims resolution free creations. When I have to wait over 26 hours for something and then finally give up because its only half way rendered then in my opinion FF has failed. I have the technology to run this....beyond what the recommended setup is... way beyond. On this day and age there is no reason why FF can't make the jump to GPU based or assisted processing power. Its necessary.
I love the promise of FF and envision what it should be doing. I just hope that it WILL do that someday. I too have been using PS since '91 and have seen some tremendous stuff happen that I never dreamed would be possible...
My comments are not against you or your filters....just FF.
Chris
Ah don't worry. I'm not really trying to poke at anybody honestly. I'm just trying to even out the argument. Once in a while these "FF is slow" arguments arise but most often it seems like SOMETHING can be done about it. Like I really don't see FilterForge being awfully slow. I see it doing it's thing at a pretty natural rate, and that's my experience in dealing with complex pieces of software involving high customizability and high quality output.
Actually this might catch your interests. It's been discussed on the forums that basically algorithms used in FilterForge can't hop on the GPU boat. In the end, I'd want FilterForge to really invest in figuring ways out but it seems there are more walls to climb for a GPU transition (realistically speaking). In one sense, the market does a really good job presenting GPU as this magical wonder, but GPU does have severe limitations, hindered by market variability, code, and hardware limitations themselves. For example, on one machine 100% GPU render engines like Octane Renderer run smooth, where as on various other machines it'll hinder the entire system, and fail to perform as it should. GPU also has a texture resolution limit, hardware vendors have various coding strategies, different units have different this and thats, and quite a disparity between various units... so there are technical hurdles.
So for now, the dream of a full on high resolution, double-percision, fully customizable/flexible node based texture/image editor is probably something distant. Of course, it'll happen.
But aside from that hard reality, I think it's still something good to invest in. If in any case there's a really really similar node-based texture editor capable of producing quality "art" that's GPU based and etc etc, I'd be happy to jump on that boat. I do use Substance Designer on the side of life n things, but I personally just like FilterForge over it's flexibility. It's insanely flexible.
In the end, I do come from the sort of "technical artist" background and to me, when I see arguments like "Software X is slow" it kinda makes me want to leave a couple commentaries about it. I seriously don't intend on arguing things, if I sound like I am, sorry... I really really just want to leave second thoughts around.
This topic really does have depth and it's well worth noting how intricate everything is. That's kinda all I want to really get at. smile;)
Imagemaker63
Here it is 2022 and Filter Forge is still slow as molasses. I've read through several threads that attempted to address this issue (all the way back to 2008!), but all I've found were excuses or personal battles and arguments on semantics. Why is Filter Forge agonizingly slow when rendering? I think this software has really great attributes, but the speed in which it renders is a dealbreaker. I just can't do this anymore. This issue needs to be addressed at the engineering level and I'm puzzled as to why a fix hasn't been created yet. It's only been years this issue has been prevalent.
ARRRGH!
Michael Griffin
