Targos
Game Dev
When you open the components in the filter edit window, and scroll, the node view zooms. So you are wanting to scroll through components but because the node view is behind, it gets the scroll treatment too.
Cheers!
In windows I only can zoom in and out inside the filter editor when I am using the mouse wheel. If you want to use scroll around the filter when zoomed in there are two ways
1 - Use the right mouse button so the pointer is changed to a hand and you can scroll
2 - Press the spacebar key and use the left mouse button to do the same
Of course that as said this is in Windows, so maybe in Mac is different and does not work this way, and there could be also a bug that does not happen in Windows.
Targos, this is a known issue to be fixed in one of the future updates.
