johnE
JohnE
I would appreciate any help I can get with this issue:
I am getting regular crashes with Filter Forge on my MAC running Maverick (10.9) when applying filters. I am running the Trial which has now expired.
I just get a dump screen and then the program closes. Any suggestions on how to diagnosis this and fix the problem. I like the product but I do not want to purchase it if it will not run reliably on my computer. I am processing smaller jpgs and if it does this fairly regularly with them I can't imagine what my 60mb raw tiffs will do.
Since my trial has expired I guess the only way to see if this can be fixed is to purchase the product so I would appreciate any insight as to if these type of issues can be resolved satisfactorily.
Running Standalone not PS Plugin
Using jpg files
Using the following filters: Cutline, Watercolor and Old Drawing
Hardware:
Model Name: MacBook Pro
Model Identifier: MacBookPro10,1
Processor Name: Intel Core i7
Processor Speed: 2.6 GHz
Memory: 16gb
Thanks.
JohnE, you definitely shouldn't buy software that doesn't work for you.
When Filter Forge crashes it prompts you to generate a bug report. If it does please post it here or send it to the support team.
johnE
JohnE
Thanks for your reply.
Unfortunately I have to purchase FF now to diagnosis it because my trial has expired. The holiday season is not the best time to download a trial smile:).
Before I purchase to diagnosis, the question I have is should FF software run without issue once setup properly on a Mac? My MacBook Pro is a top of the line current model, 1 year old so I think that hardware should be sufficient.
johnE: 1) yes, FF works correctly for us;
2) hardware should not be an issue, it looks like a software problem;
3) your case qualifies for a trial extension: please contact the support team to request a temporary license key that will allow you to either troubleshoot the issue or refrain from purchasing.
johnE
JohnE
Here is a screen debug dump after a crash. I just updated the program to the most current version and then just searched the filter list for "cutline" and the application crashed.
Process: Filter Forge [10118]
Path: /Applications/Filter Forge 4/Filter Forge.app/Contents/MacOS/Filter Forge
Identifier: com.FilterForge.FilterForge4
Version: 4.0
Code Type: X86 (Native)
Parent Process: launchd [227]
Responsible: Filter Forge [10118]
User ID: 502
Date/Time: 2014-01-20 16:58:41.842 -0700
OS Version: Mac OS X 10.9.1 (13B42)
Report Version: 11
Anonymous UUID: CB8A8C0A-6A25-996A-CF8F-167C66A489C5
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000020
VM Regions Near 0x20:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Filter Forge 4/Filter Forge.app/Contents/MacOS/Filter Forge
__TEXT 0000000000001000-0000000000d59000 [ 13.3M] r-x/rwx SM=COW /Applications/Filter Forge 4/Filter Forge.app/Contents/MacOS/Filter Forge
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libstdc++.6.dylib 0x97dcc24d std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >::compare(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&) const + 11
1 com.FilterForge.FilterForge4 0x005eb620 std::vector<FFXLib::RandomizePresetItem, std::allocator<FFXLib::RandomizePresetItem> >::push_back(FFXLib::RandomizePresetItem const&) + 67004
2 com.FilterForge.FilterForge4 0x005eb784 std::vector<FFXLib::RandomizePresetItem, std::allocator<FFXLib::RandomizePresetItem> >::push_back(FFXLib::RandomizePresetItem const&) + 67360
3 com.FilterForge.FilterForge4 0x00088575 XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::KeyboardEventArgs const>::clone_object() const + 86353
4 com.FilterForge.FilterForge4 0x00088663 XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::KeyboardEventArgs const>::clone_object() const + 86591
5 com.FilterForge.FilterForge4 0x0075f9b9 XFW::Events::EventInvokeAdapter<Controls::ScrollableControl, Controls::ControlNotificationEventArgs const>::clone_object() const + 659
6 com.apple.HIToolbox 0x9b9abc9b TimerVector + 22
7 com.apple.CoreFoundation 0x9bda4186 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
8 com.apple.CoreFoundation 0x9bda3b43 __CFRunLoopDoTimer + 1395
9 com.apple.CoreFoundation 0x9be1e2ad __CFRunLoopDoTimers + 349
10 com.apple.CoreFoundation 0x9bd5b6c3 __CFRunLoopRun + 1779
11 com.apple.CoreFoundation 0x9bd5ad5a CFRunLoopRunSpecific + 394
12 com.apple.CoreFoundation 0x9bd5abbb CFRunLoopRunInMode + 123
13 com.apple.HIToolbox 0x9b99ae2d RunCurrentEventLoopInMode + 259
14 com.apple.HIToolbox 0x9b99aa47 ReceiveNextEventCommon + 163
15 com.apple.HIToolbox 0x9bb35a46 ReceiveNextEventInMode + 75
16 com.apple.HIToolbox 0x9bb35aaa ReceiveNextEvent + 72
17 com.FilterForge.FilterForge4 0x009a4b9e std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2586
18 com.FilterForge.FilterForge4 0x0097a2eb FFXLib::Round2::get_class_info() const + 2285
19 com.FilterForge.FilterForge4 0x0071ded0 Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 11592
20 com.FilterForge.FilterForge4 0x0007420c XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::KeyboardEventArgs const>::clone_object() const + 3560
21 com.FilterForge.FilterForge4 0x001943d5 XFW::Events::EventInvokeAdapter<FFX::LightingSettingsPanel, Controls::MouseWheelEventArgs>::clone_object() const + 17377
22 com.FilterForge.FilterForge4 0x0099b1d8 XFW::Helpers::CheckFailed::clone_object() const + 3946
23 com.FilterForge.FilterForge4 0x0099c71d XFW::Helpers::CheckFailed::clone_object() const + 9391
24 com.FilterForge.FilterForge4 0x009a080e XFW::Localization::LanguagesStorage::~LanguagesStorage() + 118
25 com.FilterForge.FilterForge4 0x00002796 0x1000 + 6038
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x98e10992 kevent64 + 10
1 libdispatch.dylib 0x956f08bd _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x956f0556 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x98e0afce semaphore_timedwait_trap + 10
1 com.apple.CoreServices.CarbonCore 0x990f5311 MPWaitOnSemaphore + 104
2 com.FilterForge.FilterForge4 0x009a4ae5 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401
3 com.FilterForge.FilterForge4 0x0097a7ba FFXLib::Round2::get_class_info() const + 3516
4 com.FilterForge.FilterForge4 0x0099b1d8 XFW::Helpers::CheckFailed::clone_object() const + 3946
5 com.FilterForge.FilterForge4 0x009a4dda std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158
6 libsystem_pthread.dylib 0x993f15fb _pthread_body + 144
7 libsystem_pthread.dylib 0x993f1485 _pthread_start + 130
8 libsystem_pthread.dylib 0x993f6cf2 thread_start + 34
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:: com.apple.CoreAnimation.render-server
0 libsystem_kernel.dylib 0x98e0af7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x98e0a16c mach_msg + 68
2 com.apple.QuartzCore 0x94333a7d CA::Render::Server::server_thread(void*) + 232
3 com.apple.QuartzCore 0x9433398c thread_fun + 29
4 libsystem_pthread.dylib 0x993f15fb _pthread_body + 144
5 libsystem_pthread.dylib 0x993f1485 _pthread_start + 130
6 libsystem_pthread.dylib 0x993f6cf2 thread_start + 34
Thread 20:
0 libsystem_kernel.dylib 0x98e10046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x993f2dcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x993f6cce start_wqthread + 30
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000020 ebx: 0x01436230 ecx: 0x00000000 edx: 0x02d0a524
edi: 0x01436230 esi: 0x01435640 ebp: 0xbfffd6f8 esp: 0xbfffd6e0
ss: 0x00000023 efl: 0x00010282 eip: 0x97dcc24d cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000020
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
remainder truncated due to size...
johnE
JohnE
another:
Process: Filter Forge [510]
Version: 4.0
Parent Process: launchd [218]
Responsible: Filter Forge [510]
User ID: 502
Date/Time: 2014-01-20 18:27:42.473 -0700
Report Version: 11
Crashed Thread: 19
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
Assertion failed: (r->shape != NULL), function assert_check_region, file Regions/CGRegion.c, line 28.
Thread 0:: Dispatch queue: com.apple.main-thread
0 com.FilterForge.FilterForge4 0x006e6efd Controls::ColorPlanePanel::~ColorPlanePanel() + 8049
1 com.FilterForge.FilterForge4 0x0071bd80 Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 3064
2 com.FilterForge.FilterForge4 0x00721e94 Controls::FormProcessingTask::invoke(XFW::OS::Environment&) + 68
3 com.FilterForge.FilterForge4 0x0097a115 FFXLib::Round2::get_class_info() const + 1815
4 com.FilterForge.FilterForge4 0x0097a2c2 FFXLib::Round2::get_class_info() const + 2244
5 com.FilterForge.FilterForge4 0x0071ded0 Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 11592
6 com.FilterForge.FilterForge4 0x0007420c XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::KeyboardEventArgs const>::clone_object() const + 3560
7 com.FilterForge.FilterForge4 0x001943d5 XFW::Events::EventInvokeAdapter<FFX::LightingSettingsPanel, Controls::MouseWheelEventArgs>::clone_object() const + 17377
8 com.FilterForge.FilterForge4 0x0099b1d8 XFW::Helpers::CheckFailed::clone_object() const + 3946
9 com.FilterForge.FilterForge4 0x0099c71d XFW::Helpers::CheckFailed::clone_object() const + 9391
10 com.FilterForge.FilterForge4 0x009a080e XFW::Localization::LanguagesStorage::~LanguagesStorage() + 118
11 com.FilterForge.FilterForge4 0x00002796 0x1000 + 6038
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19 Crashed:
0 libsystem_kernel.dylib 0x98e0f952 __pthread_kill + 10
1 libsystem_pthread.dylib 0x993f2167 pthread_kill + 101
2 libsystem_c.dylib 0x92e54340 abort + 155
3 libsystem_c.dylib 0x92e1f43e __assert_rtn + 347
4 com.apple.CoreGraphics 0x9382ec11 assert_check_region + 191
5 com.apple.CoreGraphics 0x9382f7cb CGRegionRelease + 21
6 com.apple.CoreGraphics 0x9382f7af CGSReleaseRegion + 17
7 com.apple.HIServices 0x988cee39 __HIShapeDeallocate(void const*) + 30
8 com.apple.CoreFoundation 0x9bcfe44a CFRelease + 986
9 com.FilterForge.FilterForge4 0x00760dc3 XFW::Events::EventInvokeAdapter<Controls::ScrollableControl, Controls::ControlNotificationEventArgs const>::clone_object() const + 5789
10 com.FilterForge.FilterForge4 0x00702c80 XFW::Events::EventInvokeAdapter<Controls::Edit, Controls::ControlNotificationEventArgs const>::clone_object() const + 388
11 com.FilterForge.FilterForge4 0x007042f5 XFW::Events::EventInvokeAdapter<Controls::Edit, Controls::ControlNotificationEventArgs const>::clone_object() const + 6137
12 com.FilterForge.FilterForge4 0x00709fef XFW::Events::EventInvokeAdapter<Controls::Edit, Controls::ControlNotificationEventArgs const>::clone_object() const + 29939
13 com.FilterForge.FilterForge4 0x0006e53f XFW::Events::EventInvokeAdapter<FFX::ExrOptionsForm, Controls::KeyboardEventArgs const>::clone_object() const + 3541
14 com.FilterForge.FilterForge4 0x0099b1d8 XFW::Helpers::CheckFailed::clone_object() const + 3946
15 com.FilterForge.FilterForge4 0x0006e3b9 XFW::Events::EventInvokeAdapter<FFX::ExrOptionsForm, Controls::KeyboardEventArgs const>::clone_object() const + 3151
16 com.FilterForge.FilterForge4 0x0097a115 FFXLib::Round2::get_class_info() const + 1815
17 com.FilterForge.FilterForge4 0x0097a7a1 FFXLib::Round2::get_class_info() const + 3491
18 com.FilterForge.FilterForge4 0x0099b1d8 XFW::Helpers::CheckFailed::clone_object() const + 3946
19 com.FilterForge.FilterForge4 0x009a4dda std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158
20 libsystem_pthread.dylib 0x993f15fb _pthread_body + 144
21 libsystem_pthread.dylib 0x993f1485 _pthread_start + 130
22 libsystem_pthread.dylib 0x993f6cf2 thread_start + 34
Thread 20:
truncated ...
