Hi... A friend is having a problem downloading and installing the trial... Safari is blocking installation with this message... Does anyone know why this is happening...and what to do to stop the block on installation???
Casual Pixels
Dilettante
This will be OS X which is preventing the install, not Safari.
To temporarily disable this restriction, go to System Preferences, then click on Security and Privacy.
Under the General tab, you'll see three radio buttons in the bottom half of the panel. You'll need to set it to Anywhere.
Then run the installer, and then remember to go back and reset the panel the way it was.
Thanks Casual Pixels... Much appreciated... smile:)
17 unregistered users.
