Celso Bressan
Bressan
FF3 Professional crashes all the time on PS6. No way to use it!
I have got to save the image then invoke the stand alone version which also crashes 50% of the time.
What is going on?
Do you want to easily reproduce the problem? Do this:
1) Open PS6;
2) Create a new blank canvas (does not matter dimensions, etc);
3) Invoke the FF3 filter;
4) There you go! 100% of the time it crashes!
Now, what?
Is FF4 working fine?
Thanks.
Bressan
We're unable to reproduce this.
KatWillow
Mine does the same thing. I have to re-boot my Mac over and over. This computer never was the "crashing" kind before now. Sigh. That's why I'm reading the forums. I get the feeling that when I try to use FF through PS, the photoshop app is trying to load all the Filter Forge filters. Or something....
KMWillow
Celso Bressan
Bressan
It's funny, Kath, because sometimes invoking FF directly from PS it crashes, sometimes running directly the executable it crashes too. But, as far as I could see, it only works either way, that is, whenever it runs inside, it does not run outside and vice-versa. Go figure!
I don't reboot my Mac but rather I close everything that I can close and most of the time it starts working again. Definitely, FF does not know how to proper manage the memory. I was hoping to test FF4 but so far I could not get a key (I have already used the 30-day trial period). However, the previous version of FF4 was not any better...
What to do now, GMM? I have already bought the update to FF4 but I can't test it...
Thanks.
Bressan
There are also some filters that run lua scripts which kinda crash the program and get a bit annoying on you. If that was invoked then it'll run into some bad cycle of epic irritation. I think FF4 actually fixed that problem. I don't speak on the behalf of FF but I doubt the problem has to do anything with memory management and if it does, well ok fine it does.
Lastly, fix your permissions if crashes occur frequently. In most cases it'll solve any annoyance.
I don't know everything and I'm just a forum dweller, but I think most problems are solvable, just that they're difficult to get to sometimes.
Do note that we all have different parameters for our macs (what you installed, what system preferences you got, what programs are running...) and that kinda leads to a bajillion possibilities where the problem rests. If crashes are persistent you may want to look through your log files, also check what programs are running at the time. Run diagnostics... If a problem can't be replicated, it's not the end of the road. smile:)
KatWillow
This sounds odd, but the problem doesn't happen if I "open" a file in Photoshop to play with, ONLY when I create a new file. It seems to be working now, tho very slow. I hope to get the knack of it one of these months. I just got Filter Forge yesterday, so its a little early for me to get agitated.
KMWillow
Does the standalone version least work in your favor? Sorry I keep editing my little notes: if in any case you run into further issues, you should probably check the console. Application > Utilities > Console just to kinda look for oddball error messages. You can always submit problems via contact.
You can request the beta key here.
As for the crashes, unfortunately I cannot give any specific advice when we have no steps to reliably reproduce your issue.
KatWillow
smile;) I have discovered 2 things: so long as I do not create a "new file" in photoshop (I'm using CS4 and Elements11), but instead OPEN an existing file, there is no trouble applying Filter Forge!
AND. BUT- I also must move my Photoshop file over to the center of my computer screen. Otherwise it freezes in front of the Filter Forge page, and most of the time it can't be moved. A couple of times I was able to close FF and then PS worked OK.
I suspect these are Photoshop bugs rather than FF. So far I am having a real BLAST with FF.
KMWillow
Celso Bressan
Bressan
Kath:
Indeed, FF is a real blast! There are some filters that are of no use at all while others are really good.
I just got my FF4 licenses to play with and let's see how it goes.
I am using PS6 and never noticed the behavior you mentioned. Perhaps, PS is to be blamed for.
I will keep this space updated whenever I have something new.
Thanks.
Bressan
Kath (and everyone who experience crashes with new documents in PS), please provide the following info:
- your Mac OS version;
- your Filter Forge version;
- whether your Photoshop is 32-bit or 64-bit (shown in Help > System info);
- a screenshot of the New image dialog window in Photoshop – to which you're applying Filter Forge.
Celso Bressan
Bressan
GMM:
The second part of the memory dump:
0x7fff8e1c0000 - 0x7fff8e1d6ff7 com.apple.ImageCapture (7.1.0 - 7.1.0) <1AD40E02-2126-377B-A0D2-CBB21D932558> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8e1d7000 - 0x7fff8e1e0ff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
0x7fff8e1e1000 - 0x7fff8ede7fff com.apple.AppKit (6.7.5 - 1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8ee8c000 - 0x7fff8ee97ff7 com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8ee98000 - 0x7fff8eec3fff libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
0x7fff8eed8000 - 0x7fff8eedbfff libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8f830000 - 0x7fff8f874ff7 libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <B2A38D2C-7E82-34C5-8896-48C37B0E64A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff8f875000 - 0x7fff8f880fff com.apple.CommonAuth (2.2 - 2.0) <77E6F0D0-85B6-30B5-B99C-F57104DD2EBA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff8fa64000 - 0x7fff8fa68ff7 com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8fa79000 - 0x7fff8fb56fef libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
0x7fff8fc08000 - 0x7fff8fc47fff com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8fc48000 - 0x7fff8fce9fff com.apple.LaunchServices (480.40 - 480.40) <C936A07F-0CF8-3F8E-BDB3-76AA7611B4CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8fcea000 - 0x7fff8ff5efff com.apple.CoreImage (7.99.1 - 1.0.1) <4BB09B79-275B-364C-9466-0FF36ABB1218> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff9004c000 - 0x7fff9008cff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <7D2E5016-A960-3ADE-B042-F74063E79550> /usr/lib/libcups.2.dylib
0x7fff900b7000 - 0x7fff9016aff7 com.apple.CoreText (220.22.0 - ???) <A7A1096F-A211-3775-BA33-08FE98D27F08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff9016b000 - 0x7fff901eefef com.apple.Metadata (10.7.0 - 627.37) <B9BEB598-B6F2-3BFF-A8F3-C3C87CD076AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff901ef000 - 0x7fff9025ffff com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff90260000 - 0x7fff90264fff libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <35D606B1-7AD9-38E3-A2A9-E92B904BDDE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff90265000 - 0x7fff90270ff7 libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
0x7fff90271000 - 0x7fff9030bff7 com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff9030c000 - 0x7fff9031bfff com.apple.opengl (1.8.1 - 1.8.1) <51B34133-CEE3-3FC6-82AC-ADF567AE673C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff9031c000 - 0x7fff9032eff7 libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
0x7fff9032f000 - 0x7fff9038cff7 com.apple.QuickLookFramework (3.2 - 500.18) <C36371BF-E1F6-3DF7-83EA-CE96FCDCE4C4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff9038d000 - 0x7fff9041fff7 com.apple.CorePDF (3.1 - 3.1) <F81F99A9-7FF6-3A6A-92C7-78C76BA35777> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff90420000 - 0x7fff9044bff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
0x7fff9044c000 - 0x7fff9052afff com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff9052b000 - 0x7fff90542fff com.apple.CFOpenDirectory (10.7 - 146) <E71AE4A2-F72B-35F2-9043-9F45CF75F11A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9056c000 - 0x7fff905dffff libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
0x7fff905e0000 - 0x7fff905e5fff libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
0x7fff90634000 - 0x7fff90648ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff90649000 - 0x7fff9096bfff com.apple.JavaScriptCore (7534.57 - 7534.57.3) <3A04B8FC-CFA6-3AEB-8FDF-B0525B5A4C82> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff9096c000 - 0x7fff9096cfff com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff9096d000 - 0x7fff90a86fff com.apple.DesktopServices (1.6.5 - 1.6.5) <5E7DD5F4-B4DA-3F75-A14A-3494E81CFBA0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff90a87000 - 0x7fff90a87fff com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff90a88000 - 0x7fff90eb5fff libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff90eb8000 - 0x7fff90ebefff com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff90ebf000 - 0x7fff91130fff com.apple.QuartzComposer (5.0 - 236.10) <F8560AEC-4E26-3A43-BE0A-B20FCB5B2E7D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff911a5000 - 0x7fff911aafff libGIF.dylib (??? - ???) <58A4492D-AAE7-3B8F-8B06-62867471A3EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff911ab000 - 0x7fff911baff7 libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
0x7fff911bb000 - 0x7fff91433fff com.apple.imageKit (2.1.2 - 1.0) <23470050-28FB-3B09-8E27-ADC371B0E4B8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff91434000 - 0x7fff9149fff7 com.apple.framework.IOKit (2.0 - ???) <FE838BB6-D42E-3291-A1A0-6F53FC970261> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff914a0000 - 0x7fff914aaff7 liblaunch.dylib (392.39.0 - compatibility 1.0.0) <8C235D13-2928-30E5-9E12-2CC3D6324AE2> /usr/lib/system/liblaunch.dylib
0x7fff914ab000 - 0x7fff914bdff7 libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
0x7fff914be000 - 0x7fff914c5fff com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff914c6000 - 0x7fff914eafff com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff914eb000 - 0x7fff91502fff com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff9150f000 - 0x7fff9151cfff libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <72C53E7B-C222-3BE5-9984-FDC328CC4846> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff9155c000 - 0x7fff9155cfff com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff9155d000 - 0x7fff9166afff libJP2.dylib (??? - ???) <6AF1F5FC-34D4-3278-BEBB-0712B81890B4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff9166b000 - 0x7fff916a6fff com.apple.LDAPFramework (3.2 - 120.2) <275D4298-C435-3E98-AA25-95D9D0A56550> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff916a7000 - 0x7fff9170fff7 com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <9987DC46-2A96-3BA0-B88B-04E573C0AD9B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff91710000 - 0x7fff91846fff com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9184c000 - 0x7fff9189ffff com.apple.AppleVAFramework (5.0.16 - 5.0.16) <6F9A4BCE-8B99-3144-BCF7-B4299B27F6E9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff918a0000 - 0x7fff918a0fff libOpenScriptingUtil.dylib (??? - ???) <A7847713-F410-39C0-884F-A7188A18E742> /usr/lib/libOpenScriptingUtil.dylib
0x7fff918e8000 - 0x7fff919cce5f libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
0x7fff919cd000 - 0x7fff91a0efff com.apple.QD (3.40 - ???) <47674D2C-BE88-388E-B1B0-03F08BFFE5FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff91a0f000 - 0x7fff91a2efff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
0x7fff91a2f000 - 0x7fff91bbaff7 com.apple.QTKit (7.7.1 - 2339) <2BC2CF44-CEAF-3D3B-A250-CA59D6AFB0B0> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff91bbb000 - 0x7fff91c31fff com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff91c5e000 - 0x7fff91ce2ff7 com.apple.ApplicationServices.ATS (317.12.0 - ???) <BE3C156D-8326-37AA-BC4E-D3C0D31BF976> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff91ce3000 - 0x7fff91d3fff7 com.apple.HIServices (1.21 - ???) <B012EE97-D1CD-3F4B-812D-9AC7E6852FE6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff91d45000 - 0x7fff91d91ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff91d92000 - 0x7fff91da8fff libGL.dylib (??? - ???) <A4876AE9-DDFE-3B9A-874E-09BC29D46C39> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff91da9000 - 0x7fff91daafff libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff91dab000 - 0x7fff91daefff com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff91db1000 - 0x7fff91df5ff7 com.apple.MediaKit (12 - 602) <0C2CBEDA-412F-3DDF-9C74-44114E5E0DB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff91df6000 - 0x7fff91e08ff7 libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
0x7fff91e52000 - 0x7fff91e72fff libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <66C9F9BD-C7B3-30D4-B1A0-03C8A6392351> /usr/lib/system/libsystem_kernel.dylib
0x7fff91e73000 - 0x7fff91e74ff7 libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
0x7fff91e75000 - 0x7fff91f72ff7 com.apple.avfoundation (2.0 - 180.50) <A2EAE4E6-4DBA-3AAB-A387-7E72B93B6DA9> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff920e9000 - 0x7fff92130ff7 com.apple.CoreMedia (1.0 - 705.94) <700C6863-7A8F-34FA-8B1D-7659EC95000B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff9213f000 - 0x7fff9215cff7 com.apple.openscripting (1.3.3 - ???) <F5E34F54-CE85-334B-8F25-53581D43960C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff9215d000 - 0x7fff92252fff libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
0x7fff92253000 - 0x7fff92261fff libdispatch.dylib (187.10.0 - compatibility 1.0.0) <8E03C652-922A-3399-93DE-9EA0CBFA0039> /usr/lib/system/libdispatch.dylib
0x7fff92262000 - 0x7fff922ddff7 com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff922de000 - 0x7fff92354ff7 libc++.1.dylib (28.4.0 - compatibility 1.0.0) <A24FC3DA-4FFA-3DD2-9DCC-2B8D1B3BF97C> /usr/lib/libc++.1.dylib
0x7fff92355000 - 0x7fff92395fff libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
0x7fff92396000 - 0x7fff92399ff7 com.apple.securityhi (4.0 - 1) <7146CB8E-B754-3B0E-A74E-77E9138A81C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff9239a000 - 0x7fff9239bfff liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
0x7fff9239c000 - 0x7fff923c5fff com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff923c8000 - 0x7fff924cdfff libFontParser.dylib (??? - ???) <D2E56B6E-3182-3667-A78C-4172C435523A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff924ce000 - 0x7fff924d4fff libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
0x7fff927ae000 - 0x7fff927bcff7 libkxld.dylib (??? - ???) <01161870-E3B3-3F87-BA4A-0AA7A081F409> /usr/lib/system/libkxld.dylib
0x7fff927bd000 - 0x7fff927f6fe7 libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.smile8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
0x7fff927f7000 - 0x7fff93195a27 com.apple.CoreGraphics (1.600.0 - ???) <576777EA-921B-3D94-98C3-40A9CF8EBD18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff93196000 - 0x7fff93196fff com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff93197000 - 0x7fff931d7fe7 libGLImage.dylib (??? - ???) <0B7DAB2B-F1C6-39C7-B864-61EF683B6656> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff931d8000 - 0x7fff932e4fff libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.smile8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
0x7fff932e5000 - 0x7fff93306fff libPng.dylib (??? - ???) <E2B52527-4D0C-3595-BB13-8E8EF364E998> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff93307000 - 0x7fff93308fff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
0x7fff93309000 - 0x7fff93335ff7 com.apple.CoreServicesInternal (113.19 - 113.19) <74532B3B-EDE0-3553-9BED-F02B9CDF1FF7> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff93355000 - 0x7fff93434fff com.apple.ImageIO.framework (3.1.2 - 3.1.2) <047DFE61-500F-3F11-9881-D0844D2FCE5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff93435000 - 0x7fff934baff7 com.apple.Heimdal (2.2 - 2.0) <FF0BD9A4-6FB0-31E3-ABFB-563FBBEC45FC> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff934d7000 - 0x7fff934d8ff7 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
0x7fff93503000 - 0x7fff93505fff com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff9350a000 - 0x7fff93525fff libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <DDB91E75-A2FA-331F-8069-999127AC6A9D> /usr/lib/libexpat.1.dylib
0x7fff93529000 - 0x7fff93584fff com.apple.ImageCaptureCore (3.1.0 - 3.1.0) <9F7C4D81-5CC7-3D66-AC66-81EA9A5EAB94> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff93585000 - 0x7fff935b2fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <7BEBB139-50BB-3112-947A-F4AA168F991C> /usr/lib/libSystem.B.dylib
0x7fff935b3000 - 0x7fff935bafff libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
0x7fff935bb000 - 0x7fff937e5fe7 com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9380f000 - 0x7fff9380ffff libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 4
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 5779
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=330.0M resident=146.6M(44%) swapped_out_or_unallocated=183.4M(56%)
Writable regions: Total=564.9M written=176.9M(31%) resident=238.2M(42%) swapped_out=12K(0%) unallocated=326.6M(58%)
REGION TYPE VIRTUAL
ATS (font support) 31.9M
ATS (font support) (reserved) 8K reserved VM address space (unallocated)
CG backing stores 12.7M
CG image 404K
CG raster data 304K
CG shared images 3440K
CoreGraphics 16K
CoreImage 4K
CoreServices 2004K
IOKit X 76.0M
MALLOC 174.5M
MALLOC guard page 64K
Memory tag=240 31.7M
Memory tag=242 12K
OpenCL X 8K
OpenGL GLSL 1024K
STACK GUARD 56.1M
Stack X 49.3M
VM_ALLOCATE 181.7M
__CI_BITMAP 80K
__DATA 36.5M
__IMAGE 528K
__LINKEDIT 63.6M
__TEXT 266.4M
__UNICODE 544K
mapped file 54.2M
shared memory 15.5M
TOTAL X 1.0G
TOTAL, minus reserved VM space 1.0G
Model: Macmini5,3, BootROM MM51.0077.B10, 4 processors, Intel Core i7, 2 GHz, 8 GB, SMC 1.77f0
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x802C, 0x31364A53463531323634485A2D3147344431
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x802C, 0x31364A53463531323634485A2D3147344431
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE4), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS727550A9E362, 500.11 GB
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 2
USB Device: PTZ-431W, 0x056a (WACOM Co., Ltd.), 0x00b7, 0xfa120000 / 4
USB Device: BRCM20702 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8281, 0xfa113000 / 7
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: USB to ATA/ATAPI Bridge, 0x152d (JMicron Technology Corp.), 0x2338, 0xfd130000 / 5
USB Device: USB Optical Mouse, 0x0461 (Primax Electronics), 0x4d22, 0xfd120000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
annettep38
Hi I have got the same problem.
FF standalone (latest version as of yesterday) runs fine.
In CS5 FF crashes, no matter which file or size or type.
Mac OS 10.6.8, Mac Book Pro 2011.
annettep38
I will try to attach the crash log, it is always the same thing smile:cry:
____
no doesn't work.
here are two relevant bits.
Process: Adobe Photoshop CS5 [5174]
Path: /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
Identifier: com.adobe.Photoshop
Version: 12.0 (12.0x20100407.r.1103) (12.0)
Code Type: X86-64 (Native)
Parent Process: launchd [175]
Date/Time: 2013-05-09 16:23:52.257 +0200
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 19602107 sec
Crashes Since Last Report: 131
Per-App Interval Since Last Report: 18436484 sec
Per-App Crashes Since Last Report: 37
Anonymous UUID: A9FCC4D5-ACBB-4734-9384-27716C23F3F4
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Error Formulating Crash Report:
*** -[NSCFDictionary setObject:forKey:]: attempt to ins ert nil val ue (key: Identifier)
0x865fd766
0x89537f03
0x865fd5a7
0x865fd534
0x86bf5cee
0x00005572
0x864e4917
0x0000541c
0x00007fb4
0x00008aa0
0x0000ad72
0x0000ab4f
0x84a7e4c0
0x0000a256
0x84a71fd6
0x84a71e89
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libstdc++.6.dylib 0x00007fff82a49d55 __cxxabiv1::__pbase_type_info::__do_catch(std::type_info const*, void**, unsigned int) const + 41
1 libstdc++.6.dylib 0x00007fff82a4816e get_adjusted_ptr(std::type_info const*, std::type_info const*, void**) + 82
2 libstdc++.6.dylib 0x00007fff82a488de __gxx_personality_v0 + 725
3 libSystem.B.dylib 0x00007fff84a9dd61 _Unwind_RaiseException + 145
4 libSystem.B.dylib 0x00007fff84aab635 _Unwind_Resume_or_Rethrow + 37
5 libstdc++.6.dylib 0x00007fff82a48b87 __cxa_rethrow + 73
6 ??? 0x00000001edc01452 0 + 8283755602
7 ??? 0x00000001edc07cc6 PluginMain + 376
8 ??? 0x00000001ede7e9bb XFW::Helpers::CheckFailed::clone_object() const + 3873
9 ??? 0x00000001edc07be0 PluginMain + 146
10 com.adobe.Photoshop 0x0000000100700065 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4338985
11 com.adobe.Photoshop 0x000000010043767f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1420099
12 com.adobe.Photoshop 0x000000010043bd08 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1438156
13 com.adobe.Photoshop 0x0000000100434e4c AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1409808
14 com.adobe.Photoshop 0x0000000100439490 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1427796
15 com.adobe.Photoshop 0x000000010075d49d AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4720993
16 com.adobe.Photoshop 0x000000010075df03 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4723655
17 com.adobe.Photoshop 0x0000000100435d41 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1413637
18 com.adobe.Photoshop 0x0000000100759a52 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4706070
19 com.adobe.Photoshop 0x0000000100759e8b AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4707151
20 com.adobe.Photoshop 0x0000000100436058 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1414428
21 com.adobe.Photoshop 0x0000000100439455 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1427737
22 com.adobe.Photoshop 0x00000001004b2f96 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1926234
23 com.adobe.Photoshop 0x00000001004b4293 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1931095
24 com.adobe.Photoshop 0x0000000100071d74 0x100000000 + 466292
25 com.adobe.Photoshop 0x000000010006716f 0x100000000 + 422255
26 com.adobe.Photoshop 0x0000000100067232 0x100000000 + 422450
27 com.adobe.Photoshop 0x00000001012f0007 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16856267
28 com.apple.AppKit 0x00007fff81cbb6de -[NSApplication run] + 474
29 com.adobe.Photoshop 0x00000001012ee19c AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16848480
30 com.adobe.Photoshop 0x00000001012ef3c7 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16853131
31 com.adobe.Photoshop 0x0000000100068e82 0x100000000 + 429698
32 com.adobe.Photoshop 0x0000000100238308 0x100000000 + 2327304
33 com.adobe.Photoshop 0x00000001002383a7 0x100000000 + 2327463
34 com.adobe.Photoshop 0x0000000100002ea4 0x100000000 + 11940
_____________
annettep38
and the system bit
___________
Model: MacBookPro8,3, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.4 GHz, 8 GB, SMC 1.70f6
Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 1024 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 5.100.198.104.5)
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: SAMSUNG SSD PM810 2.5" 7mm 256GB, 238,47 GB
Serial ATA Device: TOSHIBA MK1059GSM, 931,51 GB
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 / 3
USB Device: MEDION HDDrive2GO, 0x174c (ASMedia Technology Inc.), 0x55aa, 0xfa130000 / 6
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0252, 0xfa120000 / 5
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x821a, 0xfa113000 / 8
USB Device: FaceTime HD Camera (Built-in), 0x05ac (Apple Inc.), 0x8509, 0xfa200000 / 2
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd110000 / 3
16 unregistered users.
