Colortrails
Author, Educator
In some situations, using Cmd-0 will either reduce the size of the Node Tree too much (leaving much empty space), or too little (cutting off part of the tree).
1. In Forge Window, select a filter.
2. Open the Editor
3. Start moving the grid divider to create different sized tree areas. Move the tree around, Zoom in or out to cut off part of the tree or free up lots of extra space.
4. Each time, press Cmd-0 to zoom to fit.
Result: only at random points does the tree: a) fit within the grid; b) use all but a small portion of the grid. The more common result by far, is making the tree very small (unreadable components) with lots of extra space left over.
Cheers,
Dan
