It's a pity that the SWF doesn't allow to adjust the exposure on the fly, it would be fun to tweak it in realtime on a spherical panorama.
Ah interesting.. is the spring image the correct one? I thought it was from some field or something
----That's the only one I wouldn't bet all my money on. But tell ya what, go look, and see if you can find the real "Spring" one for sure ha-ha smile:p
Beliria
wow dude you must have been way bored last night!
Mind cool to get inside the images like that smile:D. Down side dizziness from spinning around to much smile:D
very cool, the picture look different from what I expect from seeing them curved on the Hdr sphere smile:)
that's just freaky cool. did you make these swf panaramas, jffe? and if so, what did you use?
Cool, jffe!!! smile8) I'm hoping that FF gives full longitudinal control over them like that.....would make those HDRI images much more useful..... smile:devil:
----I was looking around online for the couple of free .hdr environs that Sachform gave away a couple years back and ended up checking their site to see if they had anything new for sale and found those.
----No, Sachform updated their website recently and added them.
----Yeah, took me 1/2 the time total just to find the one I *think* is the "Spring" HDRI cause they look so different that way smile:p
----Yeah, I dunno why they didn't from the start, but then I'm not a professional coder person, so perhaps there are limitations. But yeah, in V2 would be cool. smile:)
thanks, jffe.
was there suppose to be music as well or am i taking you too literally smile:|
OnyxMaster stated somewhere that they were going to do this.....but I don't know if it will be in V2 or not..... smile:|
thanks, jffe.
----Not a problem, I just posted those cause well, they were damned amusing and we all tend to like that kinda stuff ha-ha smile:p
----Yes, too literally taken ha-ha smile:p
----It seems like we asked/they responded about it a year or so ago. So it's probably on the B-list of new features at least eh. smile:D
----Meanwhile, I've been importing a 1500 X 750 .exr lighting environment since midnight (11 hours now) and it's not even half done. Hint to FF = consider making that feature use both cores in the future.
oh my lord, jffe, a 1500 x 750 exr? what are you, masochistic or something? smile:D
Should be on the A-list, IMHO.....along with full paremeter control over lighting, more HDRIs, merge lighting controls with filter controls option, etc, etc, etc..... smile:devil:
----That's 1/4 size of the ones built into FF, or at least from their original 3000 X 1500 size. And yeah, I knew it would take a while, but 400 X 200 ones (my usual test size) only take maybe 40-60 minutes, so I thought maybe 4-6 hours on the 1500 X 750 ones ha-ha, obviously I was a bit off 12 hours and counting later.
----I dunno about all that, but you might check out Geneteica 3 since it's 1) out now, and 2) offers a LOT of HDRI features from the specs.
I've been singing along anyway smile:-p smile:D
ah, i didnt even know the FF ones were 3000 x 1500.
so, is it done yet, jffe, or are you still baking?
----Well, if FF used the originals from Sachform, then they were 3000 X 1500 to begin with.
----It took 14 hours and 15 mins for the 2nd one, and probably right around that for the first one, between 13 1/2 and 15 1/2 hours. If that feature utilized multiple cores, it would probably take just about 1/2 that long, which is still forever ha-ha, but at least it could be done overnight.
so, are they worth it, jffe? are they good enough to warrant the time spent?
Yes, this is planned.
----Kind of, since most of the "time spent", was spent sleeping anyways ha-ha. The only issue I kind of had was concern about melting my 'puter ha-ha, but since it's been getting down to freezing or below at night these days, I'm not so worried about it now.
----Other than that, tough to say, since the colors aren't much different really (unless you bought some that did have red, or other shades of blue/green, or even purple etc.). I am able to get some more subtle shades of gold/brass now though. Depending on what you're rendering (for work/projects) and at what size, 750 X 375 might offer just as much really, and those only take like 2 hours or so to import (ie = if you don't need like real life picture perfect chrome reflections, and/or if you tend to boost the reflection blur internally anyways).
ok, thanks, jffe. i've done a dozen or so .exr's in FF, but never that size. if it took more than a half hour to render, i was banging on the 'cancel' key and pulling out my hair smile:)
Excellent!!! smile:beer:
----Yeah, it ain't fast, and it takes exponentially (and apparently not just proportionally so ha-ha) longer to import larger sized files. Hopefully FF will spend a few hours or a day or whatever when recoding for V2, and get the HDRI importing to use multiple cores. It seems like a minor thing, but try Genetica 3 and see how freakin' fast theirs works (and none of G3 even uses multiple cores yet).
well, i'm kinda curious exactly what it is that is done when making the .exr into an environment. i mean, what is it that takes so long?
jffe, you da man!!! .....this, at the very least, put in a reminder to Vlad for longitudinal control.....so it wasn't a waste of time at all......and thanks because having this will go a long way towards cleaning up HDRI artifacts in things like glass and metal.....by being able to use more of the sky and lessen the objects/forms/horizons..... smile:devil:
HDRI artifacts
eh? what are those?
Fences, trees, windows, staircases, etc.....in the HDR image.....create additional unwanted lines and migrated dirt/artifacts in smooth/shiny surfaces like glass, chrome, etc. Having longitudinal/vertical control of the lighting sphere would allow you to turn it up into the sky for a "cleaner" HDR image..... smile:)
----You run the risk of well, really boring lighting that way. Pretty much defeats the purpose of using real images really, might as well just fake it with some highlights like Crapa did in that one marbles or whatever filter. I can see wanting to *tame* it some, but I'm pretty sure you'll be disappointed if you just aim it at the sky and get a pinprick of light on the very edge of your glass/metal. Have you tried just messing with the internals, especially the Reflection Blur ? Once that's cranked past 50 or 75, you can't really see anything reflected, just some vague colors really, no "artifacts" in any real sense (unless yer super picky ha-ha, in which case HDRI lighting using real world pictures is simply not what you want, and you should probably go buy or make some simple light glare ones). Anyways, just trying to be helpful based on what I've heard you say before, and now, about the FF lighting.
ah! i get it. thanks, steve.
Well, not totally get rid of all of it......but lowering the horizon on them definitely cleans them up.......especially with glass. I don't like using reflection blur because it has a "bleaching out" effect that I don't like..... smile:)
thanks, steve.
Yer welcome..... smile:)
yes, reflection blur is the one i use the least, too. it tends to lower contrast quite a bit, though i dont know how you'd do a reflection blur without lowering contrast smile:)
Yeah, it is kinda like lowering the contrast while increasing gamma levels......not exactly sure what it is.....but I know that I don't like using it.....takes away from the "richness"...... smile;) smile:)
most of the times, yes. but i do use it on that 'tree top foilage' filter i just posted images of in my thread in the user gallery forum. well, on some of the images, anyways.
28 unregistered users.
