Sorry that this tutorial is only for Photoshop and this means that needs the subscription (although there is a cheaper choice in the subscription for the Photographers plan for 10$ or 12€ per month)
As you may know already that to modify the colors of any image or photo may be easy or not depending of the source you are using, for example changing a WHITE or BLACK color to any other is NOT easy to do usually, but here is the help to make it easy for you and possible. Although Filter Forge (FF) allows to modify the colors of the result of any filter using the Hue component, this may be very limited and do not give the result you may want and so here I suggest that you may export and save the FF result and open it in Photoshop and then after change the colors, and here are some tutorials that may probably help you. Maybe you may have a beautiful image created in FF from any filter, but trying to change some of the color, specially white or black, is not as easy as you may want. For example, you may have a photo of someone with a white shirt and you want to change it to another color so here are some tutorials to help you do it in Photoshop METHOD 1 - FASTEST ONE 1-Minute Photoshop - Turn Any Color to ANY COLOR Turn Any Color to ANY COLOR by Piximperfect in only 1 minute tutorial METHOD 2 - MAYBE BETTER ONE Turn White into Any Color in Photoshop (Even Black!) (just 9 minute with a great way explained and easy) Turn White into Any Color in Photoshop also by Piximperfect METHOD 3 - IF YOU WANT TO MODIFY THE OBJECT TO A SPECIFIC CHOOSEN COLOR Trick To Apply a Specific Color To Any Object in Photoshop! (also just 9 minute with a great way explained and easy to do) Trick To Apply a Specific Color To Any Object in Photoshop by Piximperfect METHOD 4 - MODIFY ONLY SELECTED COLOR FROM SOURCE TO ANOTHER ONE AND NOT THE WHOLE OBJECT If you want to select just one or a group of colors fr om the source and modify all of them you can use the Replace Color tool in Photoshop How to Use Photoshop’s Replace Color Tool by Planet Photoshop How to Replace Color in Photoshop CC - Adjust Color Selectively by Piximperfect |
| Posted: July 26, 2021 5:16 am | ||
I want to give some possible examples of this
You already know that in nature there are multiple kind of flowers in diferent colors, but may be you like one you have seen and would like to convert it to another color keeping the same tones and quality so for example here is a simple rose that is pink changed to blue |
| Posted: August 4, 2021 1:26 pm | ||
| Posted: August 4, 2021 1:36 pm | ||
Sorry that I forgot about to show the link to change BLACK into any other color as it is different way from the white to any color shown above
Best Way To Turn BLACK Into ANY COLOR in Photoshop [Including White!] Although this is for photoshop, if the software you may be using ALSO has adjustment layers, groups and blend modes, maybe you could also use this tutorial |
| Posted: January 7, 2022 2:25 pm | ||
23 unregistered users.
