I have decided to make this compilation of all the tutorials and websites that I may find and explains and show how to use and be able to get the most out of the powerful Blend Modes in different softwares and how to create artistic things with them in different ways.
You are welcome also to put any related website about this topic here I am planning to make a MULTIPLE (with up to 5) blend Modes filter in FF that is not available anywhere and could make interesting and awesome things in a cool way Blend Modes are available here in Filter Forge, in Photoshop, Affinity photo, in many other 2D and 3D software and is also used in scripting and coding (see the third link below) and they work all in the same way independently of the software used as far as I know, so it does not matter if you do not have Photoshop, you at least have FF Blend Modes are really a very powerful tool to mix and merge images with very interesting results and depending on how you use them you can get very artistic things, or use them as adjustments, or to sharpen or modify colors, etc. Here is Explained the blend Modes separated in groups for you to understand better |
| Posted: May 22, 2021 10:10 pm | ||||||||||
BLEND MODES IN FF
In FF instead of layers you have the Blend mode component that will mix two sources with the selected blend mode, and you can use if wanted multiple blend modes components combined or inside bomber with multiple sources As regrettably FF still does not have any drop down menu for choosing blend modes so the workaround I have found is to have this printed list with the number and blend mode reference for you to download and print shown here below I also this filter to use selective blend modes in FF Blend Modes WITH names FF filter with many added information for FF |
| Posted: May 22, 2021 11:25 pm | ||||||||||
COMPILATION OF LINKS
I have searched much and seen many websites, and I have selected the best ones and most professional and better explained with examples and detailed information I start with this tutorial I found that explains it detailed in this case for Photoshop that is the most used and it the explanation also is valid for FF or other similar software as all the blend Modes work in similar way How to Blend Layers in Photoshop: Blend Modes Explained
________________________________________________________________ ________________________________________________________________ Blending Modes Explained – The Complete Guide to Photoshop Blend Modes This one includes a video and very long and detailed explanation
________________________________________________________________ ________________________________________________________________ BLEND MODES FOR SCRIPTING AND WITH FORMULA Here if you are interested in using blend Modes with scripting, in this other website is shown the code and formula of each blend mode This link has been possible thanks to Sphinx that shared it Pegtop - How do Adobe Photoshop, Micrografx PicturePublisher and Pegtop XFader blend layers?
BLEND MODES WIKIPEDIA WITH FORMULA FOR EACH ONE IN ONLY ONE PAGE If you do not want to click on each link you can also have each of the formula on the Blend Modes Wikipedia ________________________________________________________________ _______________________________________________________________ Photoshop Blend Modes Explained
Here is the list of content for you |
| Posted: May 22, 2021 11:30 pm | ||||||||||
Maybe you may be thinking in the normal and most used way of Blend Modes used with 100% opacity and 100% Fill that is mostly how is used in Filter Forge and many of the video tutorials, BUT is important to remember that at least in Photoshop and other software you have the ability to modify how much the Blend mode is shown with the Opacity or Fill
For this to be understood much better, here is a really great example with a 5 grayscale gradient table The Ultimate Visual Guide to Understanding Blend Modes (with Opacity) examples for each blend mode It includes also a video tutorial
Here bellow is shown how they blend a greyscale stripes with a photo and apply opacity modified |
| Posted: May 22, 2021 11:57 pm | ||||||||||
HOW TO REMEMBER ALL OF BLEND MODES AND THEIR INTERACTION?
Maybe you may think that you can not be able to remember all of them, but you do not have to do it at start and there is a way to do it in Photoshop (and maybe also in other software) that will help you experiment and try directly Painting With Layer Blend Modes in Adobe Photoshop
Als9 you can change the Opacity or Fill amount and try again |
| Posted: May 23, 2021 12:20 am | ||||||||||
18 unregistered users.
