In FIlter Forge there is already available the awesome and well done automatic Auto Collage by ThreeDee but the problem with this is that is limited to 16 photos and you have to load them all one by one manually
If FF could be able to have a way to load images from a folder would be really incredibly awesome, but that I think will not happen Well, If you have Photoshop CC, I have found a way to be able to make automatic photo collages with hundreds or thousands of photos that are positioned correctly without overlapping and perfectly distributed photos of any size and ratio and load automatically your selected photos The only bad thing is that you will not be able to add and customize the edges frames of the photos as it happens in ThreeDee filter Here is tutorial that shows you step by step how to do it easily How to use Photoshop Photomerge to automatically make photo collages |
| Posted: February 5, 2021 2:22 am | ||
This example above is a much varied and different photos without any order or theme, but you could make artistic photo collages with specially selected photos about one specific theme, for example being all photos of cats, dogs, flowers, or all roses, or with different color scheme
| Posted: February 5, 2021 2:28 am | ||
16 unregistered users.
