If you use 3D meshes and they have a high amount of polygons and you may need to have it in lower amount to make a low poly model there are many different ways to do it in different 3D software
But I have just found this Free tool that does not depend on any 3D software and it works standalone, and it works really well according to many users and makes very good retopology or decimation of the original source 3D model
The most important is that this is very quick and needs very little work in comparison with other retopolgy tools that needs much work and much time, and it can be hard to retopology, but thanks to this tool, it seems that is much easier
If you do not know what Retopology or decimation is I can explain it later. Essentially in short is to be able to reduce a mesh that may have for example a millon polygons into thousands of polygon AND still mantain if possible the same shape and loose the least detail.
Here are the videos to show about it and the links to download it
32 unregistered users.
