Messages 1 - 45 of 346
I have thought to put here a thread to make a collection of images or videos that could have some inspirational ideas for things that could be made possibly in FF in some way
For example, one image maybe for me can inspire one thing, and for you could inspire a different thing that could bring other possible ideas alternatives
I start with this Video showing some geometric color shapes with checkers and stripes
Geometrical color video
I will try to make this myself and see what I can get with this
You are welcome to put any image or video of something that could be maybe done possible in FF
Thanks
I think that the Memphis style patterns and shapes can be used with.FF as they can give some cool and interesting things and I think that it will not be very difficult to make Memphis style shapes inside FF
I do not have all the expert knowledge that others may have but will try to make it and see what I can do
For example I have found this Memphis shapes seen here that could be used in FF
In B&w
Here is a possible example that could be made using bomber, although it does not have non-overlapping, I think that maybe it could work
Continuing with things that could be done in FF
I have discovered this geometric art works from James Wyper that looks great and well done
You can see all the full collection on his website www.jameswyper.com
I will see how is possible to give in FF thiese painterly brush strokes textures either using internal shapes or if not possible external ones
James Wyper 2
James Wyper 3
James Wyper 4
James Wyper 5
James Wyper 6
James Wyper 7
He uses the basic geometric shapes in such a cool and artistic ways
James Wyper 8
This is the last one, but there are many more in his website in the link above
Also have found this other design made from fractal stars that I have already started to make in FF and it looks cool and great, although I still do not know how to do the filling right
And more ways to combine these stars in a fractal
Here is the basic connection
I've got the pentagon pattern down. Have you gotten any further? I'm looking into coloring and tiling. UPDATE: 4 color pattern
and...
Great results you have done, and also that you like the idea, and below is the filter so you can see where I have reached until now
Sorry I did not have shown what I had got already before but here is my own version that is seems that is different in some way to your own.
There is still no star in the center as you have done.
Also I wanted to make possible that the internal star could have another optional color but have not done it yet.
I have also made some alternative tests, that you can see in the filter, but do not like much the results.
I did not use any loop, just using basic shapes with scale,rotate and offset
I have not done yet any Positioning of the seed for the source image of any of the color controls, it will just only put it in the center.
There is a star mode to change the outline or make it transparent, see about tab
There are 7 layers of stars in different sizes
There are some presets made
Here is the filter for FF 9
Pentagon star Recursive.ffxml
I think that as the images to be used could be interesting to use textures as source images to make something like this
Nice work. I only went to 5 layers. Here's an image from my filter showing just the wedge like the previous example. I didn't use loops either. I put some color shifting code in mine. I'll probably submit mine later.
I've submitted Star Pentagon Patterns. I've already found something I want to update, so here is the update for you to play around with it till it is out. FF9 only
Star Pentagon Patterns UPDATE.ffxml
Thanks for the update a showing your own version, and want to see how you have done it
I have found some other fractal star shape that are made inside of a star instead of a pentagon
And also one way to fill a pentagon with fractal stars
For the second part, here is showing the star pattern that is used more clearly
And another way to show the pattern showing each of the stars included
And in the same as above you can also include another star inside of the main star
I have made already a first test
I have used the STAR PENTAGON PATTERNS from Rachel Duim, and I have modified it to make a Star made of the same stars recursively, this is is just a preview
and here is the filter for FF 9
Be aware that is still in development and that it needs still one star more on each arm to fill the star
Also needs to make better the position of each arm
Star made with recursive stars.ffxml
I have just found this image shown here and thought that it could made a rectangle and square generator in FF and use an artistic filter to make it similar to this one shown here
My first initial test to reproduce something like the above example
I have thought to use Mondrian by Skybase and Sketchy Painting by emme so the first would be the source image of the second in one filter mix
Of course this needs much more work to be much more similar than the above example
You guys have permeated my conscience at work - it's relaxing to do little doodles in a CAD program.
Re: Mondrian: Try applying the paint effect only to the colored areas, masking out the black strips.
Great recursive fractal stars, well done, but this is not done then on FF and is done in a CAD software that is more easy to be done then
Good that you relax doing these things
This could be easily done in FF surely and thanks for giving the possible inspiration
I have more inspiration images
And with a square
Another one with same design but less lines
Half Hexagonal tiling with central hexagons done in a fractal way
This is tiling inside an hexagon
And using irregular distribution along a curve
Using fractal distribution tiling
With triangular tiling inside a square
And even more here
All the 9 examples above Are things I have found on internet and I think it could be possible in FF thanks to great work made by Ramlyn with the filter Q-Rotor by Ramlyn
