There is a song made by Daft Punk that could be applied to Filter Forge and you the users or Filter Forgers, the song is about a list of actions related to tecnology things, but I have thought that replacing the IT word with FF or filter, then the meaning of the lyrics of these actions are all the things you do when using Filter Forge for using or creating filters
Also surely as computer and technology users you do all these actions usually and not only with FF
Daft Punk - Technologic (4K high definition version in Paris Exhibition)
Buy it, use it, break it, fix it
Trash it, change it, mail upgrade it
Charge it, point it, zoom it, press it
Snap it, work it, quick erase it
Write it, cut it, paste it, save it
Load it, check it, quick rewrite it
Plug it, play it, burn it, rip it
Drag and drop it, zip unzip it
Lock it, fill it, curl it, find it
View it, coat it, jam unlock it
Surf it, scroll it, pose it, click it
Cross it, crack it, twitch update it
Name it, rate it, tune it, print it
Scan it, send it, fax, rename it
Touch it, bring it, pay it, watch it
Turn it, leave it, stop format it
Buy it, buy FF
use it, use FF either standalone or with host
break it, break the filters available on library to learn how they are done and learn how to do your own
fix it fix the filters that you break and make it work for you
Trash it, Thrash it if you do not like the result got from a render result with some settings or it can be also to thrash a filter
change it, if you do not like something about the result of a filter you can change it either with the settings panel or modifying the filter
mail upgrade it. You need to mail the FF support to upgrade FF to next version number
Charge it, If you are using FF in a laptop or tablet you need to charge it before you can use it
point it, You need to point at sel ected settings to modify them. Or when making a filter point to the FF components to modify settings
zoom it, You have to zoom FF components when creating a filter to see them better
press it. You need to press the buttons of your mouse or the keys of the keyboard for FF
Snap it, You need to snap the components of filter to make the aligments according to a grid for the good flow of the filter
work it, You need to work to get any results from FF to show people how great and talented you are
quick erase it. When you get an awful result from some test settings on a filter or fr om the randomizer that show something bad
Write it, Write a filter in FF to show your skills and creativity
cut it, Cut parts of a filter to be pasted in another filter as you are still not allowed to save your own components yet
paste it, Paste the cut part into the new filter
save it. Save the filter so you do not loose any possible changes, and make also a backup to be sure
Load it, Load the filter that you need , and the load the source images if they are needed
check it, Check the filter that is what you want and how you want it
quick rewrite it. If you do not like how it is, just rewrite it
Plug it, You may want to share the filter or image result and artworks, so plug a pendrive and copy them
play it, Play the filter uploaded to see again that is right
burn it, If you do not have a pendrive or external hard drive, you can burn the filter or images in a CD
rip it. When finished, rip the paper that you have used to put the data you needed to create the filter
Drag and drop it, You can drag and drop the filter to the pendrive. also you can drag and drop presets in FF 6
zip unzip it. You can zip and unzip the filter and/or images if needed
You can continue with the remaining actions replacing the it with FF related actions
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
