I have found this article with a list of good color scheme generators and thought that as many of you here are designers, it could be useful to someones.
15 Hand Picked Color Palette and Color Scheme Generators FF does not have by default any color scheme generator, or directly available possible way to make your own color schemes, you should have to build it yourself, and the only filter I have found in the FF library is Colors v1.0 by Skybase Also as far as I know, you can´t import or load any kind of color scheme into FF for a filter to use it, you can only load single colors and then after mix them with gradients. |
| Posted: November 19, 2013 2:15 am | ||
EAdams
Posts: 448 |
cool link, thanks!
| Posted: January 13, 2014 12:07 pm | ||
Tepearley
Cool! Thanks for the link! There have been times when I would make an image extremely pixelated to get colours from it and if I needed complementary colours I would just invert the pixelated image to a negative.
| Posted: January 13, 2014 8:24 pm | ||
29 unregistered users.
