If have read my previous post about New Method, I have come accross a method of getting an interesting detailed frame moulding. But it does come at a high cost as far as speed. Since there is so much going on inside of this filter with all the different rails, fillets and beads, it takes time....This pict is using the Texture Result the pict took from the moment I clicked the preset to completion roughly 20 to 25 minutes.
Using the Image result this one took less than five minutes..Its not to much
different. However there are other rails for presets that don't even resemble what they were while using the Texture results....
When I am finally done with this, one should be able to change Frame profiles, reshape the rails and the beads.. smile:)
If you would like to test this for speed beforehand just email me.....
Almost done with this one. I got the render time down by using just the IMAGE result.
Re-rendered the presets, now need to name a few controls.....
Works good in square images........
A Nice white frame here...
Just like working with the real frame moulding of this type, not all rails are exactly the same profile....
very cool, cf smile:) i think i like the white one the best.
craig
Sethren
Nice, reminds me of some picture frames i bought from The Bombay Company. smile:)
38 unregistered users.
