smile8)
How is that different from the typical 'soft focus' look ? I can't tell just by looking at the examples really.
Essentially my technique allows the use of a mask to control the blur radius. You can then simulate depth of field and other selective focus effects.
Huh, o.k. After looking at your examples again, the red outdoor scene one seems to just have blurring on the left and right sides, with an unblurred patch right down the center, so if I am seeing that right, then that is masked differently than a standard soft focus effect. smile:)
Biomechanic
Filter Licker
Nice - but how are you gonna get realistic DOF without a depth mask... smile:D
I'm curious to how you made this one - I've made my own 12 levels variable blur which uses thresholds to ensure that I'm not doing 12x blur but only use a blur component when its needed (roughly). In between the levels it mixes the floor and ceiling blur.
Btw. did you see this one already? http://www.filterforge.com/filters/520.html
My version is not as fast as this one, but its certainly more precise (notice how it looks too blended soft focus alike).
Here you go...
http://uberzev.googlepages.com/LensBlur.ffxml
I'm pretty much done with the filter, I just need to work on some presets and decide if I want to include some sample masks. (For now just replace the 'Radius' control with a map input if you want a mask controlled blur)
Interesting approach! I'll post mine when I get to the office later today, its completely different.
I just realized that I used this thing...
http://en.wikipedia.org/wiki/Gosper_curve#Properties
Here you go - I'm still working on a better max blur control and the 12 levels might be a little overkill - I'm thinking about some sort of quality control that lets you select the no. of blur steps. Notice how the thresholds ensure that a blur component is only active for a given range - this is a very nice feature of the thresholds compared to the blends: the blends always (it seems) fetch both fore- and backgound samples (regardless of opacity), but the threshold only fetches the low and high samples if needed.
EDIT - actually the max blur control will implicitly limit the no. of internal steps, so a low max blur will only use a few blur modules in practice. I tweaked a few minor things and updated the file
Variable Blur.ffxml
