Messages 1 - 45 of 158
First | Prev. | 1 2 3 4 | Next | Last |
ok, we've talked about this in other threads, but i thought it time to do something with it. i looked around on the rest of the site and didnt see anything similar so thought i'd start this.
the idea is to SEE what filter forge can do and is doing. we've got some great filters coming out, both from the developers and the beta testers, so let's show them off a bit. to make this work well, i propose using as few different base images as possible. in this way we'll be showing the differences in the filter rather than in the base image. we could use several base images that fit within some categories such as landscape, close up, portrait, black & white and so on. then, folks would copy that base image to their drives and apply their filter effect and upload the finished image back to here. i suppose there's no reason folks couldnt also load images of a given filter in that filter's thread in the Filters forum also, but for here, i'd like to compare the results of different filters to the same image. so, this is different. there is also one other small thing to contend with. some filters dont need or use a base image. filters like 'Landscape' output an image all by themselves. that's fine. for those, simply post the output image here or in the Filters forum. i'm loaning a picture of mine to start this. this is a picture i took some 35 years ago or so. it is copyrighted by me and may not be used other than on the Filter Forge web site(s). feel free to use it here on the FF site, however. if others have unique pictures that they have the rights and permissions to and would like to submit them for use, please do so. we could use a portrait type, a landscape type, a good black and white and maybe some others. but let's keep how many we use to a minimum. the idea is to compare filters on the SAME images and not compare the base images themselves. so, have fun and post often. remember, the file size limit for images being posted is currently 250k so you may have to compress some of your base and finished images. craig ![]() If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 14, 2006 4:56 pm | ||
Whitedove
Excellent idea! I was thinking of making a new thread called 'Show off your filters' where we could apply a filter to a photo or graphic and upload it so everyone can see how cool it looks. Not just your own filters, but the filters that others have made and you like.
Thanks for your pic...I will look for a good photo in my collection to upload. Donna |
| Posted: June 14, 2006 5:42 pm | ||
thanks donna. i look forward to your image(s)
ok, this is that same rose picture with 'Kaeleidoscopic Effects 1' applied to it. also, it's entirely ok if you do more than just apply a Filter Forge filter to your image. if you also want to use your graphic editor to apply other effects, why, that's fine; just so long as there is at least one FF filter applied in there somewhere. craig ![]() If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 14, 2006 5:53 pm | ||
I don't like the idea of using the same base image. After all the filters section here already has a gallery of that. I think the author should choose the image that best shows off his filter.
| Posted: June 14, 2006 6:44 pm | ||
uberzev,
the filters section does not show the filter applied to an image; it only shows the filter effect itself. so, this is different. as for using the same base image, the idea is to compare the filters. this is best done with using the same base image. this shows up the differences much better, filter to filter, than by constantly changing the base image which, in some cases, you wouldnt be able to see the whetehr the differences in final images was due to the filter or the base image. and lastly, there's no reason you cant start your own thread that uses whatever image you want. in fact, that's a good idea. we are, after all, trying to show off the filters. so, have at it craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 14, 2006 9:00 pm | ||
| momonline | ||
| Posted: June 14, 2006 10:24 pm | ||
Whitedove
Here's my first contribution a la Andy Warhol...
I cropped the original so it would be square, then ran it through Flex Tiling. Then I adjusted the red hue in each square. |
| Posted: June 15, 2006 10:01 am | ||
Whitedove
| Posted: June 15, 2006 10:22 am | ||
Whitedove
| Posted: June 15, 2006 10:23 am | ||
Whitedove
| Posted: June 15, 2006 11:38 am | ||
momonline,
very cool. glad folks are participating. whitedove, i like the warhol the hota leaf gives us our macro. good. and if you could separate out your black and white portrait, that would make it easier for others to use as their base. ok, so we have a color floral, a floral macro, and a black and white portrait. we could still use a landscape and i think a color portrait would be good also. craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 15, 2006 2:40 pm | ||
Whitedove
| Posted: June 15, 2006 2:43 pm | ||
there we go. excellent, whitedove. thanks
| Posted: June 15, 2006 2:44 pm | ||
Whitedove
| Posted: June 15, 2006 3:15 pm | ||
Whitedove
| Posted: June 15, 2006 3:18 pm | ||
very nice landscape. gorgeous, even. i shld think that would work fine. so again, thank you
and an interesting rendition. the electric blue certainly adds a flavor. craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 15, 2006 4:09 pm | ||
i couldnt resist taking a shot at your portrait. 100 years ago, ay? hmmm, i wish i'd known you 100 years ago then
lovely picture, by the way. you take it yourself? i found the black and white interesting. i've been using only color images as my base images, so it took me a while to find a suitable filter and setting. i did a little post-processing in paint shop pro as well, just to reduce a bit of the noise i'd produced with the filter. craig ![]() If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 15, 2006 4:23 pm | ||
Whitedove
WOW, I'm impressed. My father's grandmother was Iroquois indian. (Montreal, Quebec...St. Lawrence River area)
I like what you did with the photo (my husband took it using black and white film in a Minolta 35mm SLR) What filter did you use? Donna p.s. thanks for all the compliments! |
| Posted: June 15, 2006 5:23 pm | ||
Whitedove
| Posted: June 15, 2006 5:29 pm | ||
| momonline |
Donna, I love the clownfish!!!
Can you post the original so we can play with it? Sue |
| Posted: June 15, 2006 7:51 pm | ||
Whitedove
| Posted: June 15, 2006 8:03 pm | ||
whitedove,
iroquois, cool husband took it. ok, good. the filter i used was one i havent submitted yet, so, shhhh! i like the clownfish, both your rendition and the original. i think we may as well just open this up to any picture, since i'm not ever going to be able to control who posts what oh, and i forgot with all the postings to mention that i do like your Old Photo rendition, whitedove. very nice. craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 15, 2006 11:57 pm | ||
| Posted: June 16, 2006 12:10 am | ||
| Posted: June 16, 2006 12:15 am | ||
| momonline | ||
| Posted: June 16, 2006 1:58 am | ||
Whitedove
Nice job, Sue! And Kraellin, that last flower almost looks like it's underwater! Neat
I'm looking forward to that filter that you used on my portrait. Gotta go, graduation party in New Hampshire...see you all Sunday night. Donna |
| Posted: June 16, 2006 5:34 am | ||
| Posted: June 16, 2006 12:30 pm | ||
Administrator |
Craig -- that new filter looks good. I'm not sure I understand how the effect is made, it would be interesting to take a look at what's inside.
| Posted: June 16, 2006 3:42 pm | ||
Administrator |
Donna -- nice to meet you!
CFandM, cement flowers? cool
vladimir, umm, which picture? the one marked 'multiswitch'? donna, thanks craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 16, 2006 5:17 pm | ||
| Posted: June 16, 2006 6:19 pm | ||
| Northernshadow | ||
| Posted: June 16, 2006 9:14 pm | ||
| Northernshadow | ||
| Posted: June 16, 2006 9:15 pm | ||
| Northernshadow | ||
| Posted: June 16, 2006 9:17 pm | ||
thanks sherry
the watercolors are cool. i especially like the whitedove and the landscape! craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 16, 2006 9:22 pm | ||
| momonline | ||
| Posted: June 17, 2006 2:12 am | ||
| photoman |
Just wanted to show a few examples. this is the original abstract.
| Posted: June 17, 2006 12:45 pm | ||
| photoman | ||
| Posted: June 17, 2006 12:48 pm | ||
| photoman | ||
| Posted: June 17, 2006 12:49 pm | ||
| photoman |
Final variation using saturation station. Most versatile program I have ever seen.
http://www.filterforge.com/filters/555.html |
| Posted: June 17, 2006 12:52 pm | ||
momonline, very cool. what filter is that from?
photoman, is your original abstract made with an FF filter or something else? and, very cool, by the way craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 17, 2006 2:48 pm | ||
| Posted: June 17, 2006 2:50 pm | ||
| Posted: June 17, 2006 2:54 pm | ||
| photoman |
Craig,
Original abstract was done with a Photoshop filter from Mehdi called Kaleidoscope. It was a free plugin. I did the image several years ago I think it is still available. |
| Posted: June 17, 2006 2:59 pm | ||
| momonline |
Craig,
thanks, i used neonites layer and saturation station blended with normal layer. Sue |
| Posted: June 17, 2006 5:44 pm | ||
28 unregistered users.
