Redcap
Redcap
Filters: 100
I finally found out how to make a multicolored basket weave, phehhh. But I need suggestions on how to make this better, write now the filter can make a pretty good basket, but it looks more like thread which isn't a bad thing. I just want some feedback on how to improve this puppy.
Redcap
Redcap
Filters: 100
Here is a zoomed in version of the filter
Redcap
Redcap
Filters: 100
Here is an example of the filter mimicing some sort of jeans or fabric cloth
Redcap
Redcap
Filters: 100
Here is an example of the three different settings for color you have with the filter.
Red, those are looking good!!! smile8)
I really like how you are starting to get the wound vertical rope. I would suggest roughing it up just a little..... smile;) smile:)
Redcap
Redcap
Filters: 100
is this what you meant by rougher? probablly not huhh?
Redcap
Redcap
Filters: 100
again
I'm not much help, I like it the way it is and the roughness added - looks good smile:)
I think its all in the color/texture work - I think a little tweaking of the colors in your first version will do the trick. Check these reference images:
Conniekat8
Filtereurotic
Filters: 3
That's looking very slick!!!
I want I want I want... Kitty making grabby paws at the filter...
Really nice color scheme with that green smile:)
Conniekat8
Filtereurotic
Filters: 3
To look more like a basket, the horizontal weave probably needs a little bit of roundness (like they're flattened out tubes) and a little bit of sheen, if it's to be wicker.
If it's to be straw, then it needs no sheen.
