I'm weaving baskets now. I'm a little unsure about the controls to give you though. I already have one: color.
VEEEEEERY NICE! smile:)
You could add some control over HSL variation, and maybe material roughness...
Ok, got one color, a color variation which affects lightness and saturation (don't think huey would look good).
And I'm working on that roughness, which is difficult because it's a simple filter (not a surface). I've now applied a noise distortion but it still won't look right (especially zoomed in). I should find a way to make those hard egdes look more fiber-like.
Sjeiti wrote:
[...] because it's a simple filter (not a surface).
It would be nice to be able to get a bump map out of your filter, so you might want to give that one a second thought... smile;) smile:D
Also, how about some broken parts or missing threads?
Alrighty...
My second thought just went from 46 seconds to 3:47 minutes. I don't think the render time gestapo is going to allow that. But it looks nice smile:D
Maybe I took a wrong turn somewhere while rerouting everything.
Ah, you brought out the detail lines nicely in that last one..... smile8)
Looks like good ideas flying in the air smile:)
I've already done "Wooden Weave" filter and going to submit it as continuation of my weave filters.
It's very simple and fast filter yet (less than 1 minute on my machnie (with anti-aliasing)).
But main idea for future updates:
Make a "Universal Wooden Weave" filter which will include all the most popular patterns and also new non-classic weave types.
Sjeiti, maybe We could make this filter together? Result We can add under Your name.
Some samples from my filter:
you guys are rockin! sjeiti, love what you did! dont add too much height. that type of weave is fairly flat. and constantin, those are also very good!
I agree, great stuff there Sjeiti & Constantin! smile:)
Constantin Malkov wrote: Sjeiti, maybe We could make this filter together? Result We can add under Your name.
Well, I am going to submit this as a separate filter. But you're welcome to bundle it up into one big filter. It doesn't have to be in my name, I've already got my five HU's.
I just hope I'll be able to cut down on render time. Going from simple to surface just quadrupled it.
And Crapadilla, I'm trying hard to think of a way to erase threads, but haven't found one yet.
Hmmm...
Does anybody have a solution to this?
It's causing seams in my basket weave (since I implemented width as well):
Sjeiti wrote:
Does anybody have a solution...
Had the same while was preparing my weaves.
Cannot say exactly what You need in Your case as don't see snippet, but in my case decisions was the next:
1. Change THRESHOLD's controls - "Threshold" and "Smooth". Set it on more than "0".
2. Switch on ANTI-ALIASING or set it on more than "5" (not recommended - can be slow)
3. Try to see final RESULT as it can hide this.
Here is Your modified "notstraight.ffxml" snippet where is shown the first way (1):
notstraight - ways to fix.ffxml
Yeah... I've been trying to smooth it .1. Didn't think of adding another threshold behind it... thanks.
Oh well... I've just submitted the simple non-surface version of the filter, since it's way faster that the unfinished surface version. I thought I'd be a pity to leave it getting dusty in 'My Filters'. I've recently picked up Processing again, so my Filter Forge sessions are a bit on their way down.
Constantin: if you like I can send you what I have so far on the surface version of this so you can see if it's usefull for your 'Universal wooden weave'.
