MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
The Kewl Emboss, is an photo enhancement, that you can change the mood or color tones and the depth of the emboss.
Sample 1 preset4
MysticBlueRaven
Filters: 75
Sample 2 preset 5
interesting one, lynn. can you do it without changing the colors and just using white or dark lighting? the embossing, i mean.
also, just as a side point, i decided to look up the difference between 'emboss' and 'relief'.
The creation of a raised (embossed) image by pressing a shape into a sheet of paper with a metal or plastic die.
swprintserv.com/glossary.html
A kind of decoration that protrudes from the surface, like a cameo.
www.zulumoon.com/glossary/R-glossary.htm
doesnt seem to be a whole lot of difference. both seem to have the effect of a raised part of an image or object over another part that isnt. almost seemed to have more to do with the process of achieving those effects than with the end result of the effect itself. emboss seemed to be pushing a mold into a paper or other object to raise part of it, like an embossed book cover, where relief seemed to be cutting away part of something to leave part higher up, as in a coin. though, i wouldnt say that was exact or set in stone, by any means.
MysticBlueRaven
Filters: 75
looks intesting the second pic has come out very dark on my pc - craig right about the emboss and blind emboss is with no ink, I think it just a terminology thing smile:)
MysticBlueRaven
Filters: 75
Thank you very much for you comments and information. I will be renaming this filter, to something more to what this filter does.
lynn, i hope you're not re-naming it based on my comparison of emboss and relief. i was not implying that anything was wrong with the name of the filter or with the filter itself. it's just one of those goofy things i do, look up words when i'm not quite sure of one or find something interesting about one. in this case, i just went, 'now, wait, what's the difference between emboss and relief?'. so, your filter simply stirred that question in my head and it really wasnt a case of me trying to subtley imply something about your filter.
mispost....
