Presidio
From the filter description page
---------------------------------------------------- This filter uses Ron Viers snippet called 'Blur and High Pass Demonstration'. Softens your image or photo with a romantic ambience. Allure is reminiscent of 1940's Hollywood glamor shots for the stars of the time. This filter also mimics the greats in photography like Ansel Adams and turns your photos into masterpieces. Original credit from Ron's Viers snippet: Thanks to ByRo for his work in this area. For Filter Artists: The snippet used for this filter can be found in the snippet category, please do check it out. The name of the snippet is Blur and High Pass Demonstration. Please bear in mind that this filter is not a snippet. Please use the snippet to create verses using this filter to create with, the snippets are there for filter artists to create with, so... have some fun and use a snippet~ Happy creating~ Kudos to all the snippet artists~ The snippet is amazing~ Thanks Ron~ -------------------------------------------------- Link to Ron's Snippet Blur and High Pass Demonstration: http://www.filterforge.com/filters/3523.html Now on his snippet page you don't see much of an effect ... the effects are left for you to plug in and play with. A great snippet~ Original image~ Click to view larger image~ |
| Posted: August 19, 2007 4:29 pm | ||
Presidio
| Posted: August 19, 2007 4:33 pm | ||
Presidio
| Posted: August 19, 2007 4:34 pm | ||
Presidio
| Posted: August 19, 2007 4:41 pm | ||
15 unregistered users.
