Presidio
Presidio
Filters: 43
From the Filter Description Page
Decoupage: Glued images with cracks~
This filter gives delicate hairline cracks.
Some of the presets like the first one have a layer of tissue paper glued on the cutouts.
Controls:
Remove Glue, Final Glue Layer, Glue Shift, Glue Cracks Color Picker, Dry <> Wet Glue, Use Spray Varnish, Age, Glue Amount, Use Plate Surface, Glue Cracks, Stretch Cracks
Change the color of the glue cracks and determine glue amount.
20 Presets
This filter is a combination of two of my filters and a snippet (5 components and one curve) from 'Ub's weavee filter' via his filter stash in the User Gallery. Thank you Ub~
I have Ub's components shifted over to the far bottom left if you want to use them and credit Ub on your filters description page.
Please give a mention on your description page should you use this filter or parts of it as a base to create with. Thanks~
Tips...
This is a filter that layers well upon itself. After testing for a couple of hours...
take the first preset and apply...
every preset has been tested to be applied over preset 1
This pops the tissue paper color (it's already glued on your cutout) and enhances the Decoupage look. For those that want a thick application,,, layering the rendering works great. I have samples showing the difference using just 'preset 1'.
Click to view larger images~
Presidio
Presidio
Filters: 43
Click to view larger images~ smile:D
1 Layer of Decoupage using Preset 1
Presidio
Presidio
Filters: 43
Another layer of Preset 1 on top of the first layer (remember all of the presets have been tested as a layer on 'preset 1' and will work just great)~
Click to view larger image~ smile:D
Presidio
Presidio
Filters: 43
Preset 1 on the Life P~
Thank you for viewing~ smile:D
Presidio
Presidio
Filters: 43
Download Link:
http://www.filterforge.com/filters/4034.html
Remember the layering tip by applying the filter presets on top of each other ... have fun~ smile:D smile:D smile:D
(((The samples here btw are washed out by the web. I think you'll be pleasently surpised to take this filter for a test drive.)))
