garbanzo
Filters: 58
any suggestions how i could make this a bit more realistic?
garbanzo
Filters: 58
another:
Rawn (RawArt)
Texture Artist
Filters: 105
Looks very good
If I could suggest maybe a slight blurring (or even have a blur slider as an option), because any printing on course fabric will not have crisp edges.
Rawn
Nice! I like it.
You could also add a subtle noise distortion to the print stencil itself. That always helps realism.
garbanzo
Filters: 58
thanks for the suggestions!
i should have never got this program, it can be quite time-consuming smile:)
Rawn (RawArt)
Texture Artist
Filters: 105
muharharharhar---Hahahahhhhhahaha---harharharhar---muharharharharhar--hahaha--ha---ha---------ha
ummm.......yep...you got that right LOL
Rawn
no depth in the burlap. burlap has that dimension. not sure what you used to get what you've got, so hard to suggest what to use to give it more depth.
Presidio
Presidio
Filters: 43
Well the easiest way for someone new would be to go to the lighting tab and adjust surface height if it's a surface filter.
Good filter Garbanzo! Let us know how your projects are coming along~
