Messages 1 - 45 of 48
ahimsa
Filters: 41
Hi, I've been trying to get more neon like glows into my filters, but this is as far as I've managed and still not really sure how I am doing it. Has this already been done?
I did one called "NeonGlow", but completely different.....an effect on external image.....
This one is really cool.....looks like an ultraviolet effect smile:)
Presidio
Presidio
Filters: 43
Oh I like it!!!
I don't think so... could be wrong. Looks good!
ahimsa
Filters: 41
Stevie, I will check yours out. I may have already done that, but I'm still having some confusion.
Thanks Persidio, glad you like it. smile:)
Okay, I tried to get those smilies, but I couldn't understand the German (?) instructions smile:)
Anyone know a good "free" smilie site.....better yet, one that lets you customize your own???
ahimsa
Filters: 41
Right click...save...
DAZ has a free emotiguy right now that you can do stuff with in Poser. I did go to a site a few years ago that had a small program where you could make your own. Let me see if I can find it.
ahimsa
Filters: 41
Ha Ha .....very funny smile:D LOL....
Can they be loaded up in a post for everyone to have access to them???
ahimsa
Filters: 41
I was trying to figure out a way to add them here. I can do a zip file.
Here is the filter.
Glowing Metal.ffxml
ahimsa
Filters: 41
Here is where you can get the first zip full.
http://www.4shared.com/file/20258868/..._19_1.html
you can make your own in any .gif animation program. shld be some freebies still out there. i use psp's animation shop 3.
oh, sorry, ahimsa. i got sidetracked by the smilies smile:)
enchanting pattern and colors. if you want some neon effects, try playing around with some of the curves components. skewing the colors with curves can often produce a neon effect.
ahimsa
Filters: 41
I'll give that a try. I have a number of things I want to get done first and then I will see what I can do. I like bright colors in case you hadn't noticed. smile:D
bright is good smile:)
Presidio
Presidio
Filters: 43
smile:D smile:D smile:D Me too! Honest you cannot go too bright for me... hit me with bright colors and I'm a happy camper!
Can't wait to see how this filter turns out!
TY for the smilie links... no time to make my own...
ahimsa
Filters: 41
I hope I can get the filter to work. Right now it seems those colors are the only ones I can really get to do that.
Revelation
Filters: 14
Wow...very nice! The sample looks like it is actually glowing! Awesome use of colors and light!
ahimsa
Filters: 41
Thank you smile:)
Presidio
Presidio
Filters: 43
Have you tried the lighting in the control panel?
Hummm not sure why only the one preset is going neon...
How's it going? smile:D
ahimsa
Filters: 41
I have some that have a nice look to them, but I wouldn't call it neon. I use the lighting smile:D
MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
Is this the look you are going for?
ahimsa
Filters: 41
Yeah, I like how it glows with the purple.
ahimsa
Filters: 41
Here's some samples
ahimsa
Filters: 41
Click on these as the compression is making them look bad.
ahimsa
Filters: 41
Sample 3
ahimsa
Filters: 41
Sample 4
MysticBlueRaven
Filters: 75
They are looking good ahimsa
Glowing Metal2.ffxml
ahimsa
Filters: 41
I really like your purple and blue one. I may just add it as a snippet as what I have so far is so limiting.
MysticBlueRaven
Filters: 75
or you can use this one I sent after all it is yours filter I just added a few things to it
ahimsa
Filters: 41
It's still limiting. I did make a marble with it, but it leaves a band in the middle so I am leaving it out. I removed sliders that weren't doing anything at all.
Presidio
Presidio
Filters: 43
Ahimsa is that the current ffxml file? I grabbed it to help out... I cleaned it the aesthetic's so that the processes look neater...
I saw all the sliders... you said you removed some that were not working. Most of them also looked like they needed proper names.
Also... you have no curves plugged in... if you put up a recent file I can play with it some as well and pass it back. Then Lynn can grab it... or visa versa~ smile:D
If ya' want... ??
You want neon right? If you want to do this the newest copy would be best to work with. Up to you.
Looks like you have it under control. smile:D smile:D smile:D
Passing back the neater copy so that you can see how it cleans up. Nothing else was touched.
ahimsa
Filters: 41
Here is the one I cleaned.
I already submitted it as a snippet for anyone who wants to make us a nice neon filter. smile:D
Glowing Metal y1r.ffxml
ahimsa
Filters: 41
I need to work with the curves more. smile:D
Presidio
Presidio
Filters: 43
You can have some of mine... hang on and I'll grab you some from one of my filters...
BRB
Lynn just posted a new background pattern up... going to take a peek and comment then I'll some curves for ya~ smile:D Then you can play with them and change it up... but it should be enough to get ya going,,, brb
ahimsa
Filters: 41
Thanks smile:)
Presidio
Presidio
Filters: 43
Sorry about that... trying to get a nine year old to bed at the same time trying to get you some curves...
Okay this is what I did... you had several sliders holding the pattern down to a tiny size... ripped them off.
Added modifed curves from my Carmel & Chocolate filter... then modifed some more.
I got side tracked by a different look (being rushed at the moment)... I think you might want this look so I'm sending it over. Under two of the curves you'll see some empty sliders ready to plug in to Impulse and Circular Arc... left those for you to plug in... so that you can name each one as you do.
Rip and tear out the curves you do not want... add ones you do want... however this should give you a base to work with.
Also you can connect the two curve structures (you'll see two seperate curve structures when you open the file.
And don't forget to take a look at the presets before you change it... youza!!! LOL
I luv curves!!! smile:D (So now you know my secret... which is curves... play with them and have fun)).
Sending the file then I'll get some presets up... sorry I got side tracked from the neon... I'll work on that when I can get my little one to sleep promise...
Hugs smile:D
Jean
Presidio
Presidio
Filters: 43
preset 9
Presidio
Presidio
Filters: 43
click to view larger images~
these are compressed to 90%
preset 7
Presidio
Presidio
Filters: 43
preset 3 smile:D
Presidio
Presidio
Filters: 43
preset 4
Presidio
Presidio
Filters: 43
preset 8
ahimsa
Filters: 41
These are very nice glass textures. Makes me think of those bathroom dividers only spiced up. smile:)
What!? You let real life distract you? smile;) smile:D
Presidio
Presidio
Filters: 43
last one preset 5
Okay if you don't like these,,, just wanted to get a curve base for you to play with...
ahimsa
Filters: 41
Looking at the filter and I see the metal ones too. smile:)
I need to lay down now, but when I get up I will play with this. Thank you!
ahimsa
Filters: 41
I was looking at the curves. How do you know which ones to mix?
