ronviers
lighter/generalist
Hi,
I’m still not sure how it works in user gallery. I have a new filter but before I submit it I would like some advice about how to name it, categorize it, describe it, improve it etc.
Is this the correct forum to post it to or should I use the create filter forum? smile:|
Thanks,
Ron
@ronviers
Redcap
Redcap
Filters: 100
Yes, to both question. Either post here or post in create filter forum.
ronviers
lighter/generalist
Thanks Redcap.
Here is the filter and the tentative name and description. This is the first time I have name a filter of this type (whatever that is) and like I mentioned I would like to know what category it belongs to, if it is ready for posting etc.
Generate Backgrounds
This filter uses a combination of noises to generate an unlimited number of random backgrounds. This filter is designed to work using the ‘Variations’ button. Just click variations until you get a style you like then set the mode and scale. It is easy, fast and will generate a large variety of backgrounds. All of the presets were generated using variations in a matter of minutes. The filter can also be controlled directly. There are twelve basic styles, seven curves, three modes and a checkbox for either color or monochrome.
Generate Backgrounds.ffxml
@ronviers
ronviers
lighter/generalist
I’m not sure how to interpret the lack of response so I am going to submit in as a misc and see how it does. smile:|
@ronviers
Redcap
Redcap
Filters: 100
I think pics help.
ronviers
lighter/generalist
Hmmm, never occurred to me. I will keep that in mind for next time.
Thanks smile:)
@ronviers
MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
I agree with redcap pictures do help
looks like a pattern filter to me. could use it for backgrounds, but it's a pattern filter.
ronviers
lighter/generalist
Thanks Kraellin, I had ruled out pattern because, well I guess I don't know why, I didn't think it was patterny. Ultimately both the simple and surface versions ended up in misc. But now that I think about it I should have gone pattern instead.
BTW, I will correct the nonsensical wording of the surface one tonight.
@ronviers
Presidio
Presidio
Filters: 43
Hi Ron~ Have to agree a picture is worth a thousand words~ smile:D
Sounded like a pattern filter... but you say no.. .not a pattern... so...
Typically when referring to 'backgrounds'... that is a pattern filter.
Hope that helps... although without an image to look at... kinda hard to say...
How's your summer? Good? Sorry I stopped emailing... had the bottom fall out of my life for a month. LOL Everything is kewl now~ smile:D
Jean
ronviers
lighter/generalist
Thanks Persidio,
I guess my intuitive understanding of a pattern has been a little distorted by FF's square-by-nature nature.
My assumption was, and I know how crazy this sounds, was the reader of the post would load the filter, look at the presets and play around with the settings.
I was afraid something had happened but I didn't want to put the bug on you. I am hypersensitive about things like that.
So far so good on the summer. I just wish life would let me design filters and stop bugging me. smile:( smile:loveff:
You are always welcome to tell me how you have been doing - even if things have not been going well.
Take care,
Ron
@ronviers
Presidio
Presidio
Filters: 43
Hi Ron~ smile:D
Don't offer the filter... load a screen shot,,, could be of the filter on the wheel ... or an image. Just an image...
Here, Here~ Wow isn't that the truth, LOL.
smile:loveff: Not many things that can stop me from making filters.
Hey I may take you up on that and drop an email~ smile:D Everything is great now~ smile:D
Thanks for the offer smile:D
Gotta tell you... the fitlers you have been making while I've been gone are *amazing*~ Keep doing what you're doing~
Jean
