Darth Axel 007
Darth Axel 007
Filters: 29
Fixed it. My previous one, as voldemort stated, looked like it was basically blue and black rock with speckle applied to it. I've messed around with the noise and ended up with this.
voldemort
voldemort
Filters: 649
Okay just my two cents
First off the results component there is a drop down box for simplel filter or surface filter
ditch surface for simple --its the height component doing you in
add a nother perlin noise at a somewhat large scale and rough
use that as a n alpha to blend 2 versions of the night sky
so that you have colors moving in and out of one another
but the surface compnont is what is makeing this look rocky
Great first filter though just needs a little more love is all
smile:pimp:
Welcome to FF and the fun..Looks like you are off to a good start.. smile:)
Darth Axel 007
Darth Axel 007
Filters: 29
I messed around with the noise a bit, now I actually wanted them way since they have the appearance of the far away clouds.
+2 .....or use some blur on it....
+2 excellent idea.....also could add a blend of blurred, disorted, and faded gradient spectral color to get some neat color effects....
