Messages 1 - 45 of 60
Presidio
Presidio
Filters: 43
((I know another paint filter)). ((With a twist though)). smile:D
I made this for digital scrapbooking and wanted to share with new friends. Here's a peak.
It's called "Paints Old Barn Siding". I didn't add tons of sliders so that beginners would feel comfortable using it with one click. And I know the advanced users will have no problem manipulating it as a layer in their paint programs or even using it on top of other filters.
((I hope you like)).
Oh before I forget~ The image has a gloss of Ron Viers Lab Enhance (the first default preset). Mostly I use Ron's or Vlad's image enhancers- so if you have a filter you've made that is a great for this please do post the name of it to me. I will use it.
Persidio
P.S. The flower is from last years yard and grown from seed. This year we had a bad frost so I'll be using last years flower photos for another year it looks like. Unless weed photos work smile:cry:
Presidio
Presidio
Filters: 43
Here's the file~ just uploaded today but should show in the Gallery tomorrow.
Persidio
Paints Old Barn Siding.ffxml
excellent! very realistic.
and on the critique side, is there any way to speed it up without losing the quality/texture?
That's an excellent concept!!! smile:) I haven't seen anything like that before.....
Nice creative work!!! smile:)
Presidio
Presidio
Filters: 43
Hi Kraellin, Hi SteveJ,
[Oh man you both would not believe what happened yesterday. Have you seen those 'dropped call' commercials. Well I was posting to Kraellin in this thread and my Internet service was shut off ((hubby didn't pay the bill))~ he took care of it yesterday and Wha-La back on today. We are house poor so sometimes... stuff happens. smile:cry: (House poor is when your mortgage and taxes eat you alive- kinda like the movie Jaws but the banker and tax man take turns playing the shark. And that's with a cheap house- nothing fancy and built in the 70's.)]
The good news is I was working offline on this filter and have an update for it.
(((Thanks guys for the compliments!~)))
It does have a serious two min load problem. And two min waiting on a computer is excruciating. I did take out one component and only lost slight paint color manipulation. ((Can hardly tell)). Then added a small map for hue and saturation to make the paint color pop a bit more. ((It needed it)).
Some of my filters are fast loaders some medium and this one is a long 2 minutes. I may dissect it some more (by copying the elements to a blank canvas) before sending the update in later today. But I have already updated it and it's better but still slow. When I get it copied over to a new canvas I will go thru every inch of it to see if I can't rip some of the heavier components off to minimize load speed. Obviously it's going to take some time to put it thru more tests.
I need the filter for my scrap booking and figured if I need it; others might want it too. I'm so glad you guys like it.
Don't know if you layer filters but I've been doing that for years (I call it filter painting). This filter varnishes well with Ron's Viers Lab Enhance- also goes great with a filter I made yesterday that is not loaded yet- Find Edges (may rename before loading to the Gallery- the filter is a simple cross between Flaming Pears, Glare, Mr. Contrast and Organic Edges- simple filter really). When applied on the wood it enhances the grain and roughs it up just a tad while enhancing a subtle surreal feel to the image.
Sorry about the long posts (I type too fast).
What I forgot to mention about this filter prior to the updates that it still does:
#1 If you use a blank integrated canvas size of solid white, the filter will produce a solid wood grain that matches the wood grain in your painted image.
#2 On the images and on a solid white background it will produce horizontal and vertical wood grains. (The control was poorly named (my bad) and I've renamed it on the update.
(Also updated this information to show in the 'About' area.
I'll be working on minimizing the long wait before the update later today. Wish me luck~ LOL.
Persidio
Personally, I hate working on my slow ones because all my time is spent waiting for renders. I usually will not use a filter if it takes too long to render a 600 x 600.....because it will take forever to test to find what I want and render larger images.....unless the effect is worth the wait smile:)
Vlad wrote this.....which might be helpful towards increasing speed.....
1. SLOWEST: Image-based components (Blur, Motion Blur, Sharpen and High Pass) with any slow component (like Worley-based noise) as a source.
2. SLOW: Worley-based noises (any Noise except Perlin, which is very fast).
3. SLOW: Image-based components (see above) in general, because they need to prepare a source bitmap before rendering themselves.
4. CAN BE SLOW: Refraction, especially with a slow component as a source. Refraction takes 3 samples of the source input.
5. CAN BE SLOW: Any Noise (or any component based on Noise such as Noise Gradient, Noise Distortion or Noise Curve) with high Detail and Roughness (they are interdependent) especially with a custom curve as a profile.
6. CAN BE SLOW: Any Noise with a custom curve as a profile -- the curve is sampled once for each noise octave (for Details = 10 you have 10 samples of the curve per one noise sample).
5. CAN BE SLOW IN CERTAIN CASES: Any component that generates edges for anti-aliasing (Patterns, Worley noises, some of the adjustments). But since anti-aliasing is done in a separate pass, that shouldn't impact speed too much.
6. FAST: Patterns, Channels, Adjustments, Gradients (except for Noise gradient).
7. ULTRA-FAST: Externals (Image and Selection), Checker, Switch, Blend, Offset.
well, since steve posted vlad's note on speed, i'll just say that i swapped out one of the 'cell's or 'chaff's...i think it was chaffs, for a perlin noise and did the best i could to duplicate what you had in the chaffs. it's pretty close.
also, one thing not in those notes that vlad posted later is, the more stuff you have behind a refraction component, the longer it takes. so, you've got several bottlenecks in there. but, i wouldnt compromise the look for speed.
Presidio
Presidio
Filters: 43
Hi Stevie,
Exactly~ You are soooo right!!!! Now 600 x 600 is the size for a scrapbooking template. I usually save 500 x 500 seamless tiling effects as page fills for later use... then I don't have to wait on effects. For smaller tiling I use 200 x 200 to save for later use. Perfer 500 x 500 though. Unless of course the effect is for a non tiling image.
Unfortunately I do need this filter for my scrap booking and it also renders matching solid wood grain panels- I did go in and enhance the settings with the Hue and Saturation Map- figured if I'm going to have to wait it better be worth it. *grin*
Oh and I love that Vlad made that guide- I have read that previously and pull from the knowledge in it (not all my filters are slow turtles like this one, LOL). I don't think it's the slowest turtle out there...but it's a slow one.
That's the main reason I don't think it will do too well for popularity but there will be a few like myself that need it for personal projects.
Hey Kraellin,
(((((( TY on the refraction component tip )))))) and also the swap to perlin noise~
I've said it before I'll say it again ... You two are pure genius.
Persidio
Oh, I didn't mean that your filter wasn't worth it smile:) I was talking about the ones that are really slow.....you know, the ones that you wait forever to render while Final Jeopardy music plays in the background and you fall asleep in your chair.....the ones that make yours seem like a rocket in comparison smile:) Most are exceptional works, but they suck my will to live having to wait so long for them with every little adjustment smile:)
I think that it can still get popular because seasoned users understand and tolerate the wait. Like I said, there are many that are much slower than yours and they got popular irregardless of their speed smile:)
I pretend by copying things from Kraellin, Vlad, Uber, Dilla, CF, etc..... smile:D
Presidio
Presidio
Filters: 43
LOL StevieJ~ No I know you weren't saying that smile:)
You know if the filter is loading like a .pfm or .exr then nothing is worth that for a filter application. LOL ((Read the thread on that one- created .hdr files- took to another program - then to another and ended up with a nice .pfm ---- now that was a wait. Went to load the thing... ARGH.
Or if you have to apply the filter at night then go to sleep to let it finish.
Scrap bookers and graphics gals I think would love the filter... ((I like it)) but... ((looks around)) I think I'm the only woman who posts in the forum (?) and there must be other women using FF??? Not so sure this is a "man's" filter (know what I mean). LOL I should have called it "Estrogen Paint Filter".
Laughing yet? haha
You are a hoot!~
you're welcome. hope you can use those without comprosing the effect.
and thanks, persidio. and like stevie said, we stand on the shoulders of giants. so, if there's any genius, i credit it mostly to being able to recognize other genius... and then rip it off smile:D but, thank you smile:D
and as for waits, i remember the old 8 bit days of computing where you rendered in terms of DAYS, not minutes or seconds. but, that doesnt mean any of us like to wait smile:)
whitedove, northernshadow and at least one other are female. and i'm sure there are many others out there lurking. but like almost any forum on the net, the ratio of posters to lurkers ranges from about 1 in 10 to 1 in a hundred. so, i'm sure you're not alone smile:)
Presidio
Presidio
Filters: 43
Hi Kraellin,
LOL
And...
I think you just gave away your age. Hahaha- Hehehe. smile:D
We might just be the oldest ones in here hey? And unlike most women I'm proud of my age and give it away quite frequently. smile:D ((Born in 1963)) So I know exactly what you mean about computer waits. *g* Much better now then it used to be.
Persidio
P.S. Glad I'm not the only woman around~ Fantastic~
well, i'd love to give it away. any takers?
1963... yer just a youngin' then smile:D (1950)
Presidio
Presidio
Filters: 43
You are not!!
Shoot! Thought I had you there~
LOL
Well that makes us the dinosaurs then huh? smile:D Unless there are any lurkers that want to come out of hiding to give us their age. *eg*
WOW you got me- honestly thought I was older.
Persidio
must be my childish good looks that fooled you smile;)
i think byRo is older too.
Jeeze.....I'm surrounded by a bunch of old fogies!!! smile:D LOL..... just kidding, I like the elderly..... LOL..... I'm 45.....and just a kid at heart smile:)
elderly? i've got your 'elderly', pal! smile:!: smile;)
I was surprised.....I thought you were younger than me.....and yes, in a complimentary way smile:)
Okay, all kidding aside, does FF offer a senior citizen discount??? smile:D LOL...... J/K...... as Carl would say, I'm a "cheeky bugger" smile:)
PS.....I just wanted you to know that everything I say comes from the left aorta.....the one that pumps love smile:D
Presidio
Presidio
Filters: 43
((( StevieJ ))) Had you pegged younger too. Complimentary yes- also- the Internet is saturated with young people ... younger then us I mean. (40 and 50 are still young years- just ask any 65 year old... (LOL)...
Oh this is great~ smile:D
Okay, all kidding aside, does FF offer a senior citizen discount??? LOL......
ROFL
Well when you think about it- being our age and on the computer- it's like dog years. We should seriously consider asking Vlad. You guys ask first. *grin*
(((Always in a complimentary way))).
That and... your charm.
Persidio
Yeah, most people think I'm a snot-nosed kid pretending to be an adult smile:D I'm sure Craig and Carl would agee with that smile:D LOL....
I don't think Craig is speaking to me anymore after the age jokes.....so I'm going to have to try and make it up to him somehow..... smile:)
----Wow, and I thought I was one of the oldest people on FF, go figure, and no wonder my 80's jokes crash and burn. smile:D
jffe, how old are you? smile:)
Northernshadow
Filters: 19
Persidio this filter is worth the wait, smile:)
Persidio wrote:
Born in 1963
let's see, Craig is 50, Steve is 45, jeez I fit right in here... (46, just had a birthday!) I thought everyone was prob younger...
Sherry
Craig is 50,
57 smile:) born in 50.
Ok I guess I might as well admit my age as well seeing it sounds like a retirement home here with all you oldies........ 47 in 13 days smile:D ...... Carl
Presidio
Presidio
Filters: 43
(((Happy Birthday Carl)))
Good Morning Everyone~
(((Northernshawdow))) This is too kewl; another woman and my same age (I'm 44). Have your filters in another window and will download when I'm done posting. [Beautiful work.] (((Happy Birthday to you too!~)))
Northershawdow Quote:
I thought that too~ Usually on the Internet it's fairly hard to talk to people our same age. Which I think I need to say so no one has their feelings hurt- (((I honestly think 40's are the best years of a persons life and not old at all- and if the 40's are this good; then 50's going to be even better and 50's are not old either.
Stevie J Quote:
I'm guessing he is 24? Jffe am I right? Which is 42 turned backward so he'll fit right in the 40's.
Kraellin Quote:
57 born in 50.
(Meaning Craig)
When your in your 40's and 50's don't you just round it off though? Example: 40'ish, 50'ish. smile:D
StevieJ Quote:
Yeah, most people think I'm a snot-nosed kid pretending to be an adult I'm sure Craig and Carl would agee with that LOL....
LOL. Most people assume I'm younger because I have an 8 year old -----> Had her later in life then most have their children.
StevieJ Quote:
It might have been my jokes-----> I need to make it up to him too because I think 50's are young. Intellectually he's a decade ahead of us so we may have put our foot in our mouth hey? Our bad... ((((falling on knees and begging forgivness)))).
Jffe Quote:
ROFL
Well most of us talking in this thread were in the primem of our lives in the 80's. Personally speaking I ran a marathon in 91'----> so all thru the 80's was fit and having fun with life (lots of distance running in the 80's jamming out with head phones on. LOL. Oh... hadn't thought about the 80's in a long time -----> going to stop thinking about them now.
Yea, 80's jokes... LOL.
Hugs to all and Good Morning,
Persidio
P.S. Oh forgot... my age is why I use my nick (and the Persidio of San Francisco greyed out under it is a clue). Because I was born at the Persidio of San Francisco in 1963. It is now a National Park and the hospital long since torn down- but I do have two dogs in the Pet Cemetery there. (The Persidio is under and ajacent to the Golden Gate Bridge. I don't have an avatar yet,,, but it will be of the Golden Gate Bridge. Now my nick makes sense right? LOL.
BLUEFROG
Filters: 6
Retirement home ?? How about a mausoleum ?! smile:D Just kidding. I know how tender the feelings of old folks can be ! smile;) I guess I'm a baby at 37.
-Jim
P.S. The 80's Rock! Bring back hair bands and fringed leather!
smile:D smile:D
Presidio
Presidio
Filters: 43
LOL BlueFrog!
30's were tougher then the 40's for me personally. 40 is just 36 with a 4 year degree in life. Hehehehe
Seriously the 40's are just calmer, seems to me that when I was in my 30's I stressed out more then I do in my 40's. Propably just me though.
(((Yep, your a baby)))
Persidio
LOL Bluefrog I reckon your probly in the majority in ff under 40 but it's hard most of the time to tell age.............Carl smile:)
Hey finally I have a use for this line..."I wasn't born yesterday"!
Thats where I am topping at right now..I guess thats twin babies.... smile:D
My neck and back still hurts from all that heavy leather and head banging.. smile:D
Oh on the original topic...Great filter Persidio..Good concept.. smile:)
Presidio
Presidio
Filters: 43
(((((CFandM)))))
Thank you~ Been thinking about a 'Paints Wood 2'. I don't want to mess with this one because I like the effect... let's just say 'Paints Wood 2' would have a different paint simulator that loads faster. *wink* [The need for speed]~
By the way~ I'm a big fan of your filters.
Persidio
P.S. Hey BullFrog-----> bring back anything but the leg warmers. smile:D
lol. well, i'd call you all whippersnappers but my folks would just laugh. mother is 85 and dad is 92 smile:)
smile:blush: smile:loveff:
----Apparently I had it backwards.
LOL.... smile:D Liked the Maaaash Pits, eh? smile:D LOL....
LOL.... Which means you are how old??? LOL.... smile;)
I'd like to say bring back Disco but even I won't joke about that smile:D ...... Carl
Presidio
Presidio
Filters: 43
(((Oh Carl you crack me up!~)))
Groan... disco~! Now some of the non-disco music was very very good. smile:D Van Halen, The Eagles, Dr. Hook (LOL), The Knack, Bob Seager, Paul McCartney going solo ... and let's not forget female singers like Linda Ronstadt, Oliva Newton John and a band called Abba... the list could go on and on...
then came Disco... ARGH.
LOL smile:D
Jean
Now your into my favorite part of the world.. smile:D
Presidio
Presidio
Filters: 43
LOL
You too~~~ No wonder we get along!~. smile:D
Speaking of vinyl records... I was thinking of makinig a filter like one.
And oh by the way--- they were not CD's when they came out but I do have a CD of each Seager and the Knack. And if you remember right the Knack album art is a flaming hoola hoop. That would be a great filter hey?
Now you have me craving some Seager and Knack music; Think I'll have to put some of it on. smile:D
I was digging a few songs off the new Marilyn Manson cd this weekend, the new Linkin Park did nothing for me though, only one track is "heavier" than the middle of the road rawk radio single that's out, it's a freakin' ballad album. The Knack ? Is that the "My Sharono" or whatever song ? The name seems almost vaguely familiar from the 80's. I don't really remember much about 80's stuff, cept everyone used Yamaha DX7's on everything, and too much reverb (yes, Phil Collins, I'm talking about you), and buttrock/glam metal ruled the airwaves for about half the 80's (men looking like women, yes, I'm talking about you).
Presidio
Presidio
Filters: 43
Hi jffe~
Well for those of us in our 20's in the 80's there was a prelude to the music you are referring to and this prior music is the stuff we liked the best-----> most of us. Which leaves the 80's music more popular with the new generation... don't' get me wrong it was 'okay' when the 80's music came out but it wasn't near as good as the music we'd grown up with. I believe the 80's music was spurred on by a fitness craze as the 80's music was played quite a bit in Aerobic classes. Music for an Aerobic class is picked for the beats per min of the song---> weird little fact is that your heart will try to steady itself with the song beats... typcially the prefered beats per min for a class is 138 or around there and... that's 80's music. And of course the songs for the most part had to be upbeat and fun... and wha la the songs became popular. So when you get a bunch of 40 year olds talking about music,,, it's the prior music that we remember as our favorites. For most. LOL To put it simply... Madonna (a fitness crave spurred Artist verses... Lynard Skynard... no contest. smile:D
http://en.wikipedia.org/wiki/My_Sharona Beleive that album was prior to the one listed below (The one listed below I think is their best album).
The Knack (Album Title-----> Serious Fun) You might be too young to remember these...
(I'll be) Your Mau Mau
Let's get lost
Serious Fun
One day at a time
Rocket O' Love
I want love
Forgot to mention:
Eddie Money------------------> smile:D
Lynard Skynard -------------> smile:D
Doobie Brothers
Heart (personal favorite)---------------> smile:D
and Fleetwood Mac
(I never did like Blue Oyster Clut but will mention them because they did have a following)
Styx (antoher following)
Van Halen ------------------> smile:D
The Cars
For Blues... Stevie Ray Vaughn-----------> smile:D
Jean
hehe at least use a phazer or something...
Haven't heard it yet...
Persidio wrote:
You too~~~ No wonder we get along!~. Big grin
Well both good bands, well technically "The Knack and The Silver Bullet Band"..Then Bob Seager....They are both related to "Michigan" Bob Seager in Ann Arbor and Doug Feigers brother is a big lawyer here....Althou I don't know if Doug feiger grew up in Michigan...
My favorite LP from them was "Get The Knack"...A Lot of off time and not standard 4/4 time most of the time...So its an interesting one....
But myself I have grown up on music from the 60s, 70s 80s, 90s, from the 1800s to the 16 century..So I just like music...Good and Bad...Unless its real bad..
11 unregistered users.
