I was wondering if these look realistic to you??? smile:D
Chrystalize
Encasement
Behind thick glass....
More stylized than realistic.
Hmmmmm.....I see what you mean. What do you think I should address to make the glass look more real?
Ah, I see one problem.....I forgot to put the image slightly out of focus to show depth.....like in this clear version.....
Just call it "Plastic Wrap" and it will look realistic. smile;)
One a little ot of focus.....but I'm now seeing a plastic effect at the bottom.....
That hurt smile:D LOL....
Yeah, need to get that out with more hard refraction......
go back to the first one... crystal!
Yeah, that's the one I like too..... smile:)
just a thought here... and not sure how you could do it, but i just thought of veining with glass, or vice versa, have the glass and vein it with something more opaque. also, you could try making a base crystal color and adding just tiny bits of color. by adding a hue/sat component to the color side and then taking many saves, you could make quite an animation.
uberzev LOL
The crystal one looks best to me........ Carl smile:)
been working on that one.....running glass veins along edges.....and trying to create glass roots over image objects....
Yeah, I think the Chrystal one is the best too.....so I'm just going to submit the filter for that one......
another idea that comes to me from that first pic... quartz. quartz is a semi-opaque, but looking at that first one and imagining some mineral content in there, it's not far off.
Yeah, should cover Quartz Crystal.....but will be dependent on the original image properties for the result.....
is this one a posted filter yet, steve? i'd like to plug the uni- into it and apply it to the woman picture.
Not quite yet.....seems like I'm trying to fine tune 50 different filters at once smile:) Someone said "constantly changing focus creates instability".....which I'm finding to be quite true..... smile:)
yes, that's true. one job at a time works wonders smile:)
Yeah, I think that I'm getting myself under control smile:) .....can easily get yourself overwhelmed when you are detail-oriented and have alot going at once smile:)
22 unregistered users.
