Torley
Second Lifer
That'd be a cool seamless tiling texture for some maze walls with grit added. If you color in red, yellow, and blue, it could be a Mondrian!
I'm enjoying using Filter Forge to create http://torley.com/textures
Good idea
might be interesting to run this through the anaglyph filters too.
Cool and well looking as base source for another filters and textures.
Please, how have you done this ?
Thanks
Please, Is there any filter that could make something like this shown by uberzev?
Thanks
Feed bomber with several gray scale squares, apply squeeze chaos, set particle mode to difference.
[Edit] Actually you can do this with 1 bomber. Only takes a couple clicks of a button!
Set particles 1 2 and 3 to different grayscale values. Set chance 1 2 3 to 100. Size = 100. Background = full black. Opacity Chaos = 100. Size Chaos = 50. (You may want to experiment with H and V chaos amounts). Set the tint amount to 0. Change the Particle mode to difference. Density to 3. Repeat should be a low value (like 1).
That's it. Pretty simple. Also... this thread's from the FF1 era!! What makes it special is that it probably doesn't use bombers. (Or unless I got dates wrong.)
SpaceRay, go do more experiments and do more self-created homework before asking. It's been a year, you could have figured this out if you tried. Read the stuff we've spoken up about you (they're littered all across these forums) and there are a ton of new ones you probably don't know about. They contain hints on how you can get better at using FilterForge, rather than a guy who just asks for answers. Like I say, I can help you with tutorials, but you won't get better without your own initiatives.
Do it yourself. Good luck.
13 unregistered users.
