meyendlesss
Filters: 32
A shot from the latest version... well, a new version. I decided to rebuild the whole thing, and I also decided that I will submit it. At the moment it's taking quite a while to render. I may have a look at a couple snippets and see if I can speed things up. Comments would be appreciated.
]My Webpage[/URL]
What happened to the sunset one man, no disrespect meant, but that one looked way better than the others you've posted so far, and same for this eyeball one. Maybe you can afford $249, but you can earn a free copy of FF if you submit 3 filters that get popular, in case ya didn't know. smile:)
meyendlesss
Filters: 32
I'm still working on the sunset filter... and this eyeball one. The ones I've submitted so far are just some stuff I had fun with. Others like this one, the sunset one, and some others I'd like to make sure I have working the way I want them to before I submit... there's still time left before FF is released, and since I got this program I don't sleep anymore, so I'd like to take my time and contribute at least a couple good filters to go along with the other great stuff out there. I certainly would like to get a free copy though smile;) ($249 is a lot of money for someone without a job).
One thing strikes me: Why are you leaving so much image space unused? smile:?:
You should definitely enlarge that eyeball to fill the whole image.
meyendlesss
Filters: 32
One thing strikes me: Why are you leaving so much image space unused? You should definitely enlarge that eyeball to fill the whole image.
Not sure exactly what you mean. In the image, or the actual filter itself? I'm adding control for the size of the eye. I've also added a couple other things to this filter today. I was actually going to submit it tonight, but I want to play with it a little while before I do... just to make sure it all works.
Say I'd render out a 512x512 texture of this eyeball, then I'd want to make sure that the eye has a diameter of 512 pixels, so I could use as much of the given resolution as possible. No eye size control needed, really.
