Andrey Mironov
| Posted: November 26, 2015 7:43 am | ||
Tizzipoll
Posts: 56 |
I like what you have done with this...lovely effect..
| Posted: November 26, 2015 10:37 am | ||
| Posted: November 26, 2015 4:32 pm | ||
Great! Very well done and perfect, what i see is that even at the far distance the texture is NOT distorted or damaged as it happens with other filters, this is really neat, good job
| Posted: November 27, 2015 2:16 am | ||
For the sake of discussion could you explain the math and your process of constructing the filter?
| Posted: November 27, 2015 3:35 am | ||
Nice, Andrey.
@SpaceRay: In the default preset, he has Anti-Aliasing set to "All Pixels" and "25 samples". This is what makes the texture smooth in the distance, but at the cost of increased render time. Try changing the Anti-Aliasing settings to see how it affects the texture. |
| Posted: November 27, 2015 1:44 pm | ||
Very nice. I altered this to add a little more control, check out the presets for how to use it. I hope you don't mind.
InfiniteFloor altered.ffxml Math meets art meets psychedelia. |
| Posted: November 27, 2015 4:50 pm | ||
| Posted: November 27, 2015 4:56 pm | ||
| Posted: November 27, 2015 5:08 pm | ||
One more alteration to the filter, even more control.
InfiniteFloor altered 2.ffxml Math meets art meets psychedelia. |
| Posted: November 27, 2015 5:57 pm | ||
I was wondering..... Would it be possible to make every single image standing? I mean, now the images represents the floor itself. What id the image could "stand", making an angle of 90 degrees with the floor?
If it was possible, it would allow to make things like this ....
.... where every soldier could be an image. |
| Posted: November 29, 2015 8:14 pm | ||
Using Smudge, it is possible to give the feeling of a 3D structure on an "infinite floor", as you can see in one of my filters :
But it doesn't make an image "standing". |
| Posted: November 29, 2015 8:19 pm | ||
Ramlyn, I think with the new tools, using looping from the result or bomber+ present possibilities for height mapping beyond smudging. When I get the coding bug again, I will look into this, probably examining the many forums posts showing new features & filters in use.
| Posted: November 30, 2015 7:42 pm | ||
Thanks Rick. I'll do some test too. Let's see if we find a way. It could make a very nice filter.
| Posted: November 30, 2015 9:39 pm | ||
13 unregistered users.
