Still not done with this one..I had a direction but then lost it when I started messing with the frame component...This is the result so far..Still need to fix some things..
Still another pict here
Wild. Can you make it do like figure 8 type spirals ? I like the idea of having a big shape that you can change, and also change the smaller and more intricate patterns inside it seperately, which is kind of what that looks like.
Yep still have to figure out the shaping part..One can do it manually by editing the filter but by sliders will be tricky...Heres an abstract eight..Edited it manually.
You gotta do 4 of those profile grads for the background and crossfade them, so it really looks depthful ha-ha smile:D And a gray/black super thin frame around the interior shape to make it stand out better ? Just a couple ideas, looks pretty acid inspired as it is though. smile:)
psychedel...sychodel...cychodoli.... purty! smile:)
Using the same method above here is another pict from a filter that I deceided to
focus on for submitting..Just most interesting patterns..
Maybe focus on the playing cards after this one.. smile:D
