I have some time so this is a long overdue update for the playing cards filter..You can find that here http://www.filterforge.com/filters/933.html
This will be a Playing Cards 2 since there are some new things..I have updated all the blends with the new versions, man that took a good solid day..The image is now zoomable and adjusted left and right..I am now in the process of designing a different
font style..Here is a pict so far..
I have also put in finally a pattern designer for the back of the card..Here is one the designs..
OK scratch that pattern designer at the top. The more I looked at it the more I had to change it. So I took what was going to be CF patterns 2 and merge it with the Playing Cards. Heres a pict of one design.
you are amazing, dude. i know i somewhat inspired you to re-do this one but not sure i've got the moxy or understanding to look at this one in the editor smile;)
Well the background and sizing thing I was going to put in an update, but I thought as long as I am doing that I might as well create a different font also. smile:)
smile:blush:
