Messages 1 - 45 of 126
First | Prev. | 1 2 3 | Next | Last
Finally I have decided to have also my own thread to put things I could make from filter forge tests, experiments and other similar things like the ones like Skybase Lab, Shar´s Forge or CorvusCroax´s Junkyard to name only 3 as example
Many of this could be filters that I could be making, or variations of others filters, or mixing filters, or any other thing.
As the symbol for FF is the lifesaver, for the first thing to show is something curious I have done with it and lots of tiny arrows containing also the lifesaver filling (well at least the center)
This is based on 3 different filters mixed together to make this
FF Kingfisher filler with lifesaver filled arrows
FF Kinfisher source image filled with arrows filled with the FF Lionfish
FF Lionfish with Arrow filled by FF tree
Very nice!
Thanks Skybase, is not surely up to your high and awesome level, but will try smile:)
This is using the Electric Fire by Zone12 and then multiply and use blend modes to mix them in Photoshop
Here I have been trying to use 10 source photos with transparent background to put them in tiny color paper frames and using you own background image (although I have not been able yet to show all the 10 at once)
Here is one I like much, and is what would really wish to have in FF 4.0 -- FONTS!!! but regretably I think that this will not happen smile:cry:
BUT all is not lost, as with the excelent and awesome work that ThreeDee have made with his Filter Forge own built fonts TD Europa Sans Caps Proc Font Advanced by ThreeDee you can build your own font designs. Love you ThreeDee for making this.
And also using this fonts as shapes with the awesome, special and very artistic Gradient Circles by Skybase
I got this here below
I have to say that I always try to use the filters as they come from the FF library, and want to respect and use them this way so the author can get the usage rank it deserves but sometimes I want to mix some things from one and use it with another one like in this case, although as said, as far as I can I always use the factory filter without any modification.
Here is the same from above but in bigger size to see better the details
and even bigger and more closer to see the alphabet tangled even better
and this is how it looks the FF Lifesaver with this Gradient Alphabets
And another variation with different settings to see better the 26 letters of the alphabet
And the color stripes with this bigger letters and less tangled
a black and white tiger head with eyes and nose
and for last one the FF Lionfish with this filter
I have to say that if anyone is interested, I could submit this to the library as it has been a long time and hard work modifying all and mixing it so it can work right and be it like this as shown here, and adding LOTS of more controls to use all the letters and customize them with sliders and checkboxes.
Also thanks to the good help from CFandM with this lines shapes I have been able to make a filter to mix different lines and add shadows
or mixing two images
or mixing the lines of 1 image with a different background (here the FF garlic)
Converting to metal the FF lifesaver
The FF Lionfish in a Polygon web with shadows thanks to the help of uberzev, ThreeDee and Skybase snippets and experiment filters published in the forum
And here is the same FF Lionfish but with other settings inverting the colors and effects and showing much more the shadows
and here with multi-color
or this other version
What do you get when mixing the FF Kingfisher and the Lionfish in an artistic grunge way?
now some filter I have made from a very different one to shown bold black and white shapes in seamless tiling
and this one is with shadows activated to see them more
Colorful Stones
Also you can find many more experiments I made in this other thread
What about Spirography making with images and PHOTOS ?
This ones have been done from my filter Spirograph Break Out by SpaceRay, you have to modify the inside shapes with your own ones with transparent backgrounds.
Examples shown on that thread
Also have tried to make this Scribble filter
another example of the scribble with different settings
and the inverted version
And when trying to make another different thing I got this curious effect
This is using the FF Kingfisher
Transparencies squares
and this is reducing the size pixels to have more detail
and another example with this
Also I am making a simple filter to mix two different images with geometrical stripes or triangles, or squares.
X shape stripes
and triangles
Zig zag stripes
and now with other images
All these works above mixing two images with stripes have been inspired by the artworks of the Artist Jiri Kolar and here are some of his works
Well you got a ton of stuff going on over these months. I do like your bomber experiments.
I see where you got your inspiration for those last images. Kolar's works seems to juxtapose essences of western culture and phenomenon. Kinda like viewing two ideologies engraved in society and culture forced into a single image. Very Dada-esque. Would be interested in seeing what images you'd use instead of just samples. smile;)
I feel as for the filters, they can be pushed further and almost compliment Kolar, given it's done through computers. The current filter is like a general overview of what Kolar's done, so adding to that would benefit the overall progression of his works. So for example, what if you can have more than two images? Have the 2nd and 3rd images randomly appear between different bars or have them cris-cross at exact angles. The triangle mask can be some kind of window into a separate image, where each image is represented scattered across multiple triangles. Zigzags are interesting... maybe the 3rd image is woven between the mountains and valleys, like a basket weave. The images alone can be processed individually so they can compliment, juxtapose, coalesce once together.
Excuse me... my critical art-student side came out.
Burt
Random Old Guy
Well some cool and interesting work here.
Thanks for your comments Skybase and Burt
Yes, you are right I like much the works of Kolar´s work (seen on the link above) that you can mix two different images from different theme but that could have something in common to make them match in some way. And also could be used to show two oppositte ideologies in one work but separate by the stripes so they really are not mixed. Also to match colors in contrast and opposites.
Sorry that I did not continue yet to put really meaningfull images and not just samples and tests as the ones shown above, although I will do it sometime when I can and have the inspiration.
Yes, I agree with you and you are right, the filters can be pushed further because this ones are computer generated and in filter forge that open a whole new way of making them. This filter as you say, is just an general overview, because I wanted to test first to make the simple and easy version and then after add more things to it and customize it more. And I also thought before about having more than two images and I like the idea and is good but this must be done right as it breaks the balance from the above and could look bad.
Yes, this could be done easier if the images would randomly appear, but then it would break perhaps the feeling, although I do not know, I should try and see what happens and how it looks to decide if it is good or not.
Yes, good, I agree with this and could be a good way to do it and then have more possible combinations and options.
No, I like it and all that you have said here, is good to know it and artistically oriented. Thanks.
I have found a curious way to use a very simple trick with bomber and scale and this is a simple version that I have just started, will see how I can improve it and make it better
I still did not find a name for this lines texturing
This filter now has 4 lines sources that you can move and rotate to mix them using blend modes and changing opacity, but I want to make it more control of the lighting as on some images it does not look good, so will have to see more and make more tests.
36 unregistered users.
