| Posted: May 11, 2012 2:07 pm | ||
Great and well done this version 4, as the other 3 before.
I like much the other different effect that you have here. |
| Posted: May 11, 2012 2:08 pm | ||
Cierra
Posts: 23 |
| Posted: May 12, 2012 3:36 am | ||
Thanks guys ! cierracat, I love the colors you put in your nice example. Do you remember the presets of this ?
visit https://gisoft.ca |
| Posted: May 12, 2012 9:55 am | ||
Cierra
Posts: 23 |
| Posted: May 12, 2012 6:18 pm | ||
Thanks a lot cierracat, I appreciate much.
| Posted: May 12, 2012 6:46 pm | ||
... If only FilterForge has for loops. You'll never have to string rotation and scales manually ever again.
| Posted: May 12, 2012 10:02 pm | ||
You could take uberzev's uberBlend and adapt it to get rid of the daisy chains of rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend-rotate-blend...
| Posted: May 12, 2012 10:12 pm | ||
cierracat, I also Thanks a lot and I appreciate much your beautiful example and giving the preset to make this beauty.
very well done |
| Posted: May 14, 2012 1:46 am | ||
