Messages 1 - 45 of 92
First | Prev. | 1 2 3 | Next | Last
Volumetric Explosions by Morgantao
http://filterforge.com/filters/10489.html
Great!! and very well done. Thanks for adding this to the explosion filter collection and so we have more destructive power (graphically speaking smile;) ) and combine them in different ways.
http://filterforge.com/filters/4965.html
http://filterforge.com/filters/2654.html
http://filterforge.com/filters/4638.html
ALSO this could be like a water explosion if you change the hues to blue
BTW, the last two presets are the same explosion, with only the Decay control changed. smile;)
Nice filter Morgantao smile:)
So cool! smile8) Err...I mean hot!
Totte
Ubernerd
Filters: 107
Running this through the batchrunner, must try that smile;-)
Thanks for the complements everybody! smile:)
Totte, in some cases you can get a cool blast animation with just increasing the Decay from 0 to 100. I suggest you test it on 0 and on 100, and see if Decay 0 is mostly yellow and Decay 100 is all black.
I might even post an animated gif, if I figure out how to batch 100 frames each with a Decay++.
Here's my lame attempt at animating the explosion...
It's supposed to be a high frame rate, but for some reason I can't save it with more than 24 FPS smile:(
futuremotion
Starving Artist
Filters: 5
Hey Morgantao, nice filter! Really love all the detail in the flames, especially as the decay starts approaching 100.
I'm going to have to jump in and see what's under the hood!
Not much actually smile:D
For anyone who wants to know but is intimidated by the editor, here's how it works:
I have a bunch of perlin noise modules blended togather with overlay mode. Then I use a gradient map with a 5 color gradient (Black, 2 Yellows, Orange, White) to give it the color.
All the rest is just to add some more detail into the texture.
Again I want to congratulate you for this great and explosively amazing filter!!
You can ALSO make many of this round explosions and JOIN them together to make bigger explosions of other sizes, and other shapes, as mixing 4 you could have a square and with 6 a rectangular style.
Also you could mix this with many other resources you may have and have even better explosions.
Just a note on the filter, if you use it on a 5:1 aspect ratio image, you get 5 different looking explosions.
So if you need, let's say 10 different explosions, all with the same settings, just make a new image, 1000x10000 pixels (or 10000x1000) for example, and get 10 explosions in a row.
Also, I just updated the filter, so now if you get weird black spots on the explosion, just set the Smoke Amount slider to 0.
If you're creating animations, I suggest you start with Smoke and Decay at 0, and for every 10 decay or so you add, increase the smoke by 1 or 2.
When there's alot of dark areas on the explosion, you can start increasing the smoke by more than 2.
WOW!! Cool and I did not think that this could be possible. GREAT! smile8) smile8)
It works very well and the best thing is that all are different smile:eek:
AND as they have a transparent background (if you want) it is very easy to use them without having to remove the background and make different layers and arrange them to make BIGGER explosions
and even as these are very well done you do not need to use any added blend mode
Here is 8 explosions (using the 5 of the example above) joined together to make one big explosion
and applying an overlay blend mode to all the layers you get the same but with some shades of red
And if this is not big enough, you can merge this eight explosions into 1 and duplicate it again 4 more times and rotating it and mixing around the center original one, so you will get a huge 40 explosions mixed into 1 as you can see below
And ALSO this could be used to make textures as you make this huge 40 into 1 explosion and then crop it in a square size and use is it as a background texture for other possible things
When I was going to update the filter for the new version I got this message I have put here below
If the ONLY this that has been updated is the "Black Spots" I do not care about this, as I do not know what is this and have not have any problem until now with this.
It should read "WARNING: Downloading this filter may explode your computer..." smile:D
Shouldn't make any difference for the presets.
Glad for this update Morgan
cool smile:)
dactilardesign
Filters: 56
I am making a frame by frame explosion generator editting your filter.
Looking good so far (just finished the "first half", now I have to make how the explosion dies).
"did you see that? but you knew that already because you are an advanced user"
Are you making a new filter based on this one, or using it as is to cerate an animations?
In any case, why don't you post what you have so far, I'd love to see it smile:)
dactilardesign
Filters: 56
I am making a version of yours with frame control, so you can make a frame by frame explosion evolution. Will post the WIP soon smile:)
Cool.
Right now the only way to animate it is to manualy set image size and decay+smoke amount sliders.
Would love to see your work on it, sounds like a great time saver. smile:)
dactilardesign
Filters: 56
Attaching what I have done so far.
I have freezed the shrapnel effect for now, will focus first on the explosion itself.
I am thinking on how face the decay process... I may split the filter in 2:
- first half animation ( frames 1-12)
- seccond half (13-24).
The reason why I would do this is because I think the filter will work in a different way for the last half, getting transparency and stop growing...
Any idea is welcome.
Explosion Frame Generator_WIP.ffxml
dactilardesign, I had a look at how you did the first 12 frames, and while it's a cool idea, I don't like how there's no consistency in the explosion between frames.
The thing is, for each frame, you clculate a new set of noises, and they don't match the previous frame.
Instead, here's my solution for the same. I have taken the same noise patterns on all frames, and just resized the result. Now you get a more consistent explosion.
Notice how I also attached the frame control to the decay of the explosion, so each frame also has some evolution to the flames.
Now comes the part where frames 13-24 come in. I think there should be some shrinkage, but not much, and also upward motion (also, not much). The decay should keep on going to total black smoke. I suppose the last few frames (4 or 5) should also include transparency.
I wish I knew how to make a simple logic machine using the math components, so you could have all 24 frames in one filter. I'll work on that, but don't hold your breath...
I'm not happy with the way I did the shrapnel at all. If you can come up with better shrapnel, I'd love to see it.
Volumetric Explosions animation WIP.ffxml
dactilardesign
Filters: 56
What I have been working the last hour was exactly that. The problem is not that the noises don't match, the problem is that they move too fast (my first frame count was 36 frames, and looked better).
I did that too, obviously was in the TO Do list smile:)
agreed too.
Code
As I can't code like a pro, I will split the filter in 2 stages.
I am not that good... I don't think I can do it better, I will try though.
Checking your filter.
dactilardesign
Filters: 56
Ups, I can't load your filter, it's 3.0
From my experience, should be longer.
I'll FF2 the filter so you can see it smile;)
dactilardesign
Filters: 56
update!
dactilardesign
Filters: 56
*use the "animation 1/2" checker on my filter.
Here's an update.
I managed to have all 24 frames in one slider.
Right now there's no tansparency because I'm working on something more complex than just 100% to 0% opacity.
This is still work in progress, but have a look at it and tell me what you think.
As of right now in the first 12 frames the explosion grows in size, and the decay goes from 0% to 50%, and the last 12 frames the explosion gets a little smaller and travels up the frame.
EDIT:
Rmoved the file because:
1) found a little problem with some of the frames
2) got a solution for transparency.
dactilardesign
Filters: 56
oh... looking forward to it.
Here's the new file.
Now it's logic is pretty much complete. The only thing is to tweak the settings and the timing a little.
Tell me what you think smile:)
EDIT: Arrrgh! Got anouther bug.... smile:evil:
Here's an animation I made with default preset. All I had to do, from start to finish, was to move the slider each frame and save it.
The horrible magenta background is for showing off the transparency smile:D
The animation looks a little crappy online... Frame rate is all wrong.
OK, here's the file AGAIN....
I don't care how many bugs and error I made, I'm keeping it online smile:D
Note that the animation above was made before I fixed last bug.
Also note that the nodes can be arranged better, and with less components, but my brain is too fried now to do it. It's 2:20am here... Gotta sleep a little smile;)
Volumetric Explosions animation WIP FF2.ffxml
dactilardesign
Filters: 56
2:02 heere, going to bed, checking tomorrow.
I will download before you delete it to fix something! smile:D
There is one major thing I screwed up on the filter, and that is that the backgound gets all mangled up.
It's an easy fix, just have to move the blend back to the end of the filter. I'd do it, but... I'm already in my pijamas smile:D
dactilardesign
Filters: 56
There is something I miss from your approach, and it's the smoke and fire ball movement. And it's mainly what you need for a game, because the particle system makes the size change and if needed rotation, so you want an evolving particle.
Obviously your approach is far more smart. I will try to tweak it.
dactilardesign
Filters: 56
My update.
The main problem for the smoke animation is that perlin noise always move from top left corner to lower right, so the explosion animation always has that kind of flow.
dactilardesign
Filters: 56
Preview.
btw, the filter renders much faster now smile:) thank you.
I'm not home right now, but when I get home I'll see if there's a way to offset the noise so the flow will be from the center outwards, or bottom up.
If you need any help tweaking anythin I'm glad to help. Now that I got the logic of the frame manipulation it's should be easier to get things the way you want.
So if understand you correctly, then the expanding of the explosion (and shrinking and moving upwards) is not needed? I did that because I had gif animation in mind, but if it's not needed it can be chopped out.
