Sine-O-Graph One by ThreeDee
http://filterforge.com/filters/10478.html
Very nice and amazing futuristic neon lighted geometric lines and dots graphics you can make with this.
Very well done and again is amazing what can be done with the scripts for one that knows well the programming and scripting so well as you can.
You have a very different way to think about things that could be done and be possible using the actual available components and know for sure to combine and get the most of them.
Your Genius and great knowdledge is also appreciated and valued by FF Inc. because:
You have won another EP (Editor´s Pick) !!!
Congratulations. You deserve it much.
CHECKBOX TO TURN OFF THE NEON LIGHTS ?
Although I like much and is beautifully done the glow of the neon like lines, I would like to suggest that there could be also possible to have also a way to turn off those glows and keep only the great geometric lines figures in black and white as drawing design.
Although you could keep the colors tinting for giving colors overlays to the lines designs.
Also I have the idea that this black and white without glow could be mixed toghether to make even more complex shapes toghether inside FF or probably much easier and better inside photoshop as PNG´s with transparency (without the white background) so you be able to have even more geometric collages and apply them as overlay for other images.
Ooooohhh, pretty pretty light! smile:)
I love this filter, I love how you can do that with scripts, I love that you got ANOTHER EP that you verry well deserve!
smile8)
Hi SpaceRay,
Thanks.
If you make all the colors white and set the line weight to 2, you get this:
Oooh !! Yes, very good to know this. Thanks.
Great wonder this filter.
Here first example
next one...
I have remembered about this beautiful and lovely filter, that is very innovative and technically original and well done, and that there are LOTS of different possible combinations to get lots of variations.
And one less complex and more organic curves
And keeping the colors but switching off the neon lights, just and only by reducing the Line thickness, to a value of 1 or 2.
And with another combination of 3 main colors and using straight lines instead of curves with line thickness value 2
now using a line thickness of 24 let´s it shine!!
And now lets give it a 70 value to make it full power lighting smile:)
LexArt
LexArt
Awesome and beautiful filter you have done here, like it much
I wonder if other kind of shapes or lines could be made using other possible components instead of using curves or waves
Thanks for sharing this
